javaraspi
SODIMM Connector
Wed Apr 24, 2019 11:15 pm
Hello community good afternoon.
I am planing to use the compute module in an off road application. There will be some vibration involved.
I will use some standoffs to fix the module to the PCB but i am worried about the SODIMM connector itself. Does anyone know if there is a more rugged version of the 1473005-4 (TE Connectivity)?
Thanks for your input.
Javier.
W. H. Heydt
Re: SODIMM Connector
Thu Apr 25, 2019 12:28 am
IT's the same connector that is used for holding memory DIMMs in laptops. Would you run a laptop in your car? If yes, then a CM shouldn't be any different.
javaraspi
Fri Apr 26, 2019 9:43 pm
Agree!.
Thanks for your comment.
Return to “Compute Module”
