guyver2
[python] MCP3021 resolution
Tue Apr 23, 2019 12:36 pm
Hi everyone,
I'm trying to read, through i2c and via python, values from a potentiometer using a very simple ADC, the MCP3021.
The datasheet claims 10 bits of precision but I can only get values from 0 to 15, which is you know, 4 bits of precision...
I was wondering if I'm doing something wrong here.
Here is the very simple class I use for that : https://gitlab.com/antoine.letouzey/boo ... ter/pot.py
The important line is l.23 where I read the data.
Any guess ?
I'm not a hardware expert so if you need more information just let me know.
danjperron
Re: [python] MCP3021 resolution
Tue Apr 23, 2019 2:38 pm
First you need to read 2 bytes without command byte.
Check page 18 from http://ww1.microchip.com/downloads/en/D ... 01805C.pdf
SMBus doesn't support it! You need to use IOCTL.
#!/usr/bin/env python
import io
import fcntl
import time
I2C_SLAVE_COMMAND=0x0703
i2c_address = 0x4d
FileHandle =  io.open("/dev/i2c-1", "rb", buffering=0)
# set device address
fcntl.ioctl(FileHandle, I2C_SLAVE_COMMAND, i2c_address)
def ReadAD():
     values = list(FileHandle.read(2))
     return ( values[0]* 256 + values[1]) / 4
print("A/D:{}".format(ReadAD()))
guyver2
Thu May 02, 2019 10:58 am
Thank you very much, I'll try that as soon as possible and come back to tell you if it worked out.
guyver2
Sat May 18, 2019 12:30 pm
It wasn't as soon as I expected but I finally got the chance to try your solution and it worked very nicely. I now have a value in the expected range [0-1023] instead of [0-15].
Thanks a lot.
