Mon Nov 26, 2012 11:24 pm
You're probably well-acquainted with the statistical distributions associated with electronic components' individual abilities to withstand concentrated application of our stupidity. It appears the components on your particular board were all on the higher side of the peak in the distribution curve (not really a "bell" curve for the uninitiated, but a large, lump-shaped curve, of sorts, with unevenly-sized upper and lower areas around the mean). Without incrementally jacking up the juice until something actually fails, there's really no way to know how many more lives your poor Pi may actually have. Even for nominally-average semiconductor components, they usually last either seconds/minutes or tens of thousands of hours.
I have lots of fun taking engineering students around on tours of semiconductor fabs and other electronic device manufacturing facilities and someone inevitably asks, "So, which line are the highest-quality components made on, vs. the cheapie ones?" The answer is, of course, that they're all made right next to each other, right down to the individual wafers. Even after all this time, we still can't predict which specific components will be capable of handling the highest clock speeds or otherwise maxing out in performance, and which will be DOA, and they are often fabricated side-by-side.
It's true of light bulbs, microprocessors, or microwave resonant cavities (you have to make on the order of 10,000 cavities in order to get one that meets the specs for things like medical imaging machines - the rest are just melted down and you make another 10,000 to get another good one - that's why the good ones cost hundreds of thousands to millions of dollars ... each). This also applies in varying degrees to anything manufactured in quantity, whether it's the electronics, automotive, aerospace, or other industrial sector.
The best things in life aren't things ... but, a Pi comes pretty darned close!
"Education is not the filling of a pail, but the lighting of a fire." -- W.B. Yeats
In theory, theory & practice are the same - in practice, they aren't!!!
