Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration : 3 h 2 min
Bit rate mode : Variable
Bit rate : 322 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 419 MiB (100%)
Language : English
Default : Yes
Alternate group : 1
VLC media player 3.0.6 Vetinari (revision 3.0.6-0-g5803e85f73)
[01c38e80] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[01c4f420] main interface error: no suitable interface module
[01bc9938] main libvlc error: interface "globalhotkeys,none" initialization failed
[01bc9938] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[01c4f420] skins2 interface error: cannot initialize OSFactory
[01c4f420] [cli] lua interface: Listening on host "*console".
Command Line Interface initialized. Type `help' for help.
[00150e90] vlcpulse audio output error: PulseAudio server connection failure: Connection refused
[00166f78] main interface error: no suitable interface module
[000e1938] main libvlc error: interface "globalhotkeys,none" initialization failed
[00166fe0] dummy interface: using the dummy interface module...
