I have a problem with sending a message from Raspberry pi to Arduino. I use on my raspberry pi Python IDLE to send message to my arduino uno. When I run my program, I got a problem message :
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 265, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/ttyACM0'
During handling of the above exception, another exception occurred:
File "/home/pi/Arduino Et Raspi/arduino&raspi1.py", line 4, in <module>
ser = serial.Serial('/dev/ttyACM0', 9600)
File "/usr/lib/python3/dist-packages/serial/serialutil.py", line 236, in __init__
self.open()
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/ttyACM0: [Errno 2] No such file or directory: '/dev/ttyACM0'
>>> My program on my arduino for my test is :
#define LED1 2
#define LED2 3
#define LED3 4
int message = 0;
void setup()
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
Serial.begin(9600);
void loop()
if (Serial.available()) {
message = Serial.read()-'0'; // on soustrait le caractère 0, qui vaut 48 en ASCII
switch (message) {
case 1:
digitalWrite(LED1, HIGH);
break;
case 2:
digitalWrite(LED2, HIGH);
break;
case 3:
digitalWrite(LED3, HIGH);
break;
case 4:
digitalWrite(LED1, LOW);
break;
case 5:
digitalWrite(LED2, LOW);
break;
case 6:
digitalWrite(LED3, LOW);
break;
}Code: Select all
import serial # bibliothèque permettant la communication série
import time # pour le délai d'attente entre les messages
time.sleep(2)
compteur = 0
while True: # boucle répétée jusqu'à l'interruption du programme
if compteur < 6:
compteur = compteur + 1
else:
compteur = 0
ser.write(str(compteur))
time.sleep(1) # on attend pendant 2 secondesSo help me please.
