AyoGeo
Please I need help i am a noob, how would i connect raspberry pi 3 b+ to my chromebook.
Wed Apr 17, 2019 6:46 pm
Please i have just purchased a raspberry pi 3 b+ as i would like to start learning how to code as well as learning about computers in general. I followed a page that showed me how to install the raspbian os to the sd card i followed it to the t but it did not explain now how would i connect it to my chromebook. i am currently using a lenovo chromebook as well as the raspberry pi 3 b+, i purchased the smraza kit the basic one. can someone please help me, i have looked for videos but it seems like none is for the problem that i am facing. please any help appreciated.... I downloaded the secure shell app as well I am using hotspot from my phone.... Please someone helpppp...
Andyroo
Re: Please I need help i am a noob, how would i connect it to my chromebook.
Wed Apr 17, 2019 11:45 pm
The Pi comes with two ways of accessing it remotely:
RealVNC allows you to control the GUI using a mouse and keyboard on another computer. Details here
SSH gives you a command line and is designed for lower level access. Details here
The issue you have is the 'walled garden' nature of the ChromeBook and what you can get to.
Have a look in the applications store / Goolge Play store for anything that will give you a SSH client (such as Termius or HTerm) and visit RealVnc to enrol in the Raspberry Pi FREE connection software / Internet connection capabilities.
AyoGeo
Thu Apr 18, 2019 2:54 am
I still don't understand I followed directions from I site that told me how to install the raspbian os with the ssh file in the boot path enabling ssh. I have secure shell app version 0.17 installed I don't know what to do from there I turn on the pi but don't know what to do on the ssh screen.
W. H. Heydt
Thu Apr 18, 2019 4:41 am
Sticking my neck out here... It sounds like you are connecting to your Pi with your ssh client. Do you get a screen that has something like "pi@raspberrypi ~ $" at the top? Or are you looking at "login:" at the top? If the later, you need to log in using the default credentials of "pi" and "raspberry". Then you'll have the "pi@..." prompt.
Once there, the first thing you want to do is run "sudo raspi-config". You should change the password, first off. Other things to do are: set your locale, set your time zone, set the keyboard. Then exit raspi-config. Given some of the settings you'll be doing, you will need to reboot, and it should prompt you to do that. If not, use the command "sudo reboot".
Once the Pi is rebooted, log back in using your new password.
Now you can run shell commands like ls, cd, df, and so on.
AyoGeo
Thu Apr 18, 2019 5:05 am
Ok so I found out my Pi's IP address did everything to sign in from ssh now it's telling me port 22 connection refused. I checked to make sure the ssh file is in the boot part of SD card and it wasn't so I added it but still does not work. When I check again to see if ssh is in boot it's not so I added again and still saying same thing. I wonder if I have the wrong raspberian os on the SD card. When I ping the pi it gives me the IP address. I don't know what else to do I been stuck on this for a while now.
rpdom
Re: Please I need help i am a noob, how would i connect raspberry pi 3 b+ to my chromebook.
Thu Apr 18, 2019 5:54 am
That is normal behaviour. You only need to put the file there once to enable the SSH server and it gets deleted once that is done.
Unreadable squiggle
HawaiianPi
Thu Apr 18, 2019 8:05 am
How are your Chromebook and Raspberry Pi connected to your network?
How did you find the IP address of your Pi?
Try SSH into pi@raspberrypi
Check your router settings to see if AP isolation is enabled.
FYI: SSH from my Chromebook works fine, so it can be done (we just need to figure out what's different with your setup).
W. H. Heydt
Thu Apr 18, 2019 1:48 pm
pi@raspberrypi.local
Thu Apr 18, 2019 2:11 pm
The Chromebook and Raspberry Pi both connected to your phone HotSpot ??
RPi 4B 4GB (SSD Boot)..
AyoGeo
Thu Apr 18, 2019 3:32 pm
How are your Chromebook and Raspberry Pi connected to your network? Hi
Ok so I am using my phones hotspot. I found the IP address on crosh using ping command. I followed will haley.com raspberry pi headless installation directions. Does my raspberry pi have to be connected to my phones hotspot first? If so how do I connect it to the hotspot first.
Thu Apr 18, 2019 3:40 pm
If you are not connected to something how can your devices communicate ?
https://www.raspberrypi.org/documentati ... /README.md
HawaiianPi
Thu Apr 18, 2019 6:30 pm
Either pi@raspberrypi or pi@raspberrypi.local works on Chrome OS (.local is not required).
Don't need .local with WSL either (.local doesn't even work in WSL, I think that's a Bonjour thing).
HawaiianPi
Thu Apr 18, 2019 7:48 pm
Okay, I think I found the guide you used (next time post a link, please), and it looks like the wpa_supplicant.conf file example is incomplete.
The file, wpa_supplicant.conf should look like this.
update_config=1
country=GB
network={
	ssid="Router/WiFi SSID"
	psk="WPA/WPA2 passphrase"
	key_mgmt=WPA-PSK
  • Edit country=, ssid= and psk= with your information and save the file.
I believe the missing update_config=1 line is the problem (I forget why that's needed, but one of the engineers commented on that in a previous thread). The key_mgmt=WPA-PSK line is currently optional, but it's included when the Raspbian GUI creates the file, so I recommend adding it (lots of old tutorials are now wrong because of left-out lines that became necessary later).
I just ran through the whole setup procedure on my Chromebook and it worked on my home WiFi. Then I tried it using my phone's hotspot, and that worked as well. So assuming that you have a valid wpa_supplicant.conf file, and both your Chromebook and Pi are connected to the same network, it should work.
Yes, your Pi must be connected to the same network as your Chromebook before you will be able to use SSH.
AyoGeo
Thu Apr 18, 2019 8:51 pm
update_config=1
country=GB
network={
	key_mgmt=WPA-PSK
ok thank you for your help. i typed exactly what you have into the wpa file, now the same problem when i had it the original way is happening. it stays connected for a minute than dissconects. its giving me the mac address but it is showing 0.0.0.0 as the ip address. i cant figure this out i have been reading everything i can and found out what i was doing wrong at first now that i fixed that problem i can finaly see it trying to connect to the hotspot but not staying connected.
AyoGeo
Thu Apr 18, 2019 9:03 pm
Ok now here is exactly what is going on now. i have the wpa file text exactly the way they said to up above. Now when i look under my manage devices tab in my phones hotspot it shows that an unknown device is trying to connect with a ip address of 0.0.0.0. now when it showed it was connected for two minutes i went to crosh and tried the command raspi -c 1 and it came up with a ip address. The problem is that it is not staying connected, it shows a mac address but not an ip address. There is no other raspberry devices where i am so i know that is not the problem. Everyone that has helped me so far i appreciated it so much.
HawaiianPi
Thu Apr 18, 2019 10:34 pm
That's really odd. Does your hotspot allow communication between devices (some wireless access points keep clients isolated from each other)? Are there any security settings for your hotspot app (see if you can turn off client isolation, or authorise your Pi's connection)?
Do you have a normal ISP/Router wireless network you could try it on?
AyoGeo
Thu Apr 18, 2019 11:03 pm
Ok so I am using hotspot spot on a Moto E5 play. When I go to the settings tab in hotspot and go to set up WiFi hotspot it shows the security as WPA2 PSK. Do I have to add the 2 in the wpa line code?. As far as everything else goes my Chromebook connects just fine. This is the only option I have right now is my hotspot as the wifi.
HawaiianPi
Thu Apr 18, 2019 11:12 pm
No, the wpa_supplicant.conf file should work the way I posted it (I use WPA2 security as well).
Do you know if your phone provider allows more than one connection at a time (mine allows up to 10)?
AyoGeo
Fri Apr 19, 2019 12:09 am
Yes I have had two before I was trying with 3 going to try with just two. But I don't know what else can be the problem.
PcMac
Contact: Website YouTube
Fri Apr 19, 2019 12:24 am
Try some simple things. Start with diet pi.
You can watch my videos.
DietPi: https://www.youtube.com/playlist?list=P ... 93m36xYtTZ
Here is the playlist link.
Thanks & Regards
Mr. PcMac
Thanks & Regards
:ugeek: Mr. PcMac
AyoGeo
Fri Apr 19, 2019 3:56 am
Ok so i now tried to do it with just two devices and the same thing is happening, it looks like its trying to connect to the hotspot it pops up for a second than kicks back out, i thought it was the macafee on the phone so i uninstaled that and tried again and still the same thing.
can you see anything with the way i have the code on wpa file.
update_config=1
country=GB
network={
ssid="name"
psk="password "
key_mgmt=WPA-PSK
AyoGeo
Fri Apr 19, 2019 4:23 am
i realy dont know what the problem is but below you will find exactly the way i have it setup.
update_config=1
country=GB
network={
ssid="Ayogeo"
psk="WPA/WPA2 8b618f161638"
key_mgmt=WPA-PSK
is anything missing please i dont undersrand what is going on i have connected tvs, phones and computers to my hotspot but i cant seem to connect the pi.
AyoGeo
Fri Apr 19, 2019 4:28 am
i also went to crosh now when i try the command ping raspbpi -c 1 it comes up as recieved and gives me the ip address. i dont understand what is going on.
HawaiianPi
Fri Apr 19, 2019 5:47 am
Unless WPA/WPA2 is part of your passphrase, it shouldn't be there.
The ping raspbpi command shouldn't return anything, because the default hostname in Raspbian is raspberrypi.
Did you install the SSH App from the Chrome Web Store, or just the Extension?
EDIT:
See this post for info about serial console cables (very handy for troubleshooting).
viewtopic.php?f=91&t=238513&p=1457712#p1457712
AyoGeo
Fri Apr 19, 2019 2:15 pm
EDIT:
I DL the extension. Does this matter? What else was strange is that it did it first the crosh command than it wouldn't do it but when I changed the name it did do it. I am going to change that line in the code and see if it will work.
