moryoav
Grove Gesture Sensor (PAJ7620u2) + Power Button
Wed Apr 17, 2019 5:13 am
I'd like to connect a hand gesture sensing module, like this:
https://github.com/eouia/MMM-GroveGestu ... G_0747.jpg
I'm already using GPIO3 for my power switch with a button that shorts GPIO3 + GND.
If I want to keep using the power switch, what are my options? Can I connect both the gesture sensor AND the power button to GPIO3? Multiple devices on the same GPIO pin, will that work or will it fry my pi?
Thanks.
scotty101
Re: Grove Gesture Sensor (PAJ7620u2) + Power Button
Wed Apr 17, 2019 8:27 am
You can't use both the sensor and the button on the same GPIO pin.
Swap the button on to another GPIO pin. See this site (https://pinout.xyz/) to figure out which GPIO pins are available.
moryoav
Wed Apr 17, 2019 8:30 am
I apologize, I wasn't clear enough. The button is not (just) power-off button, it's also power ON. and for that I thought the only way was to short pins 5 and GND. I followed this guide:
https://howchoo.com/g/mwnlytk3zmm/how-t ... spberry-pi
scotty101
Wed Apr 17, 2019 8:35 am
Its a pain. See viewtopic.php?t=225832
GPIO3 can be used to wake the Pi as the I2C interface isn't active when the Pi is in it's halt mode but it can't be used as a shutdown pin because the grove sensor needs to use the I2C interface.
You can have two buttons, one to wake and one to shutdown.
