dronee
CM3 Lite suddently stopped working,
Sun Apr 14, 2019 11:50 am
Hi, I am using CM3 lite module, it was working, suddenly stopped working. When i power the DEV board i see that flashing led doesn't change.
I checked small component on CM3, i noticed C42 has low voltage 0.5 v, rests looks ok, no physical damage visible.
What might be the problem, any idea? also, do you know the black chip next to C42 capacitor? i think it is the voltage converter, i am guessing it is damaged
Return to “Compute Module”
