Pavel_47
Missing sharing libraries
Fri Apr 12, 2019 12:47 pm
While executing Qt-based program, I get the following error:
error while loading shared libraries: libGLESv2.so.2: cannot open shared object file: No such file or directory.
Thnks in advance.
topguy
Re: Missing sharing libraries
Fri Apr 12, 2019 2:15 pm
It is relevant if this application was built with the standard Qt installation on Pi or not.
...but you can try this:
export LD_LIBRARY_PATH=/opt/vc/lib
You do this in the shell before trying to start the Qt application.
You should also check if the file exists in the "/opt/vc/lib" directory. You might only have "libbrcmGLESv2.so" so you might have to make a symbolic link with the name reported as missing.
ln -s /opt/vc/lib/libbrcmGLESv2.so /opt/vc/lib/libGLESv2.so.2
Pavel_47
Fri Apr 12, 2019 2:42 pm
Thanks,
export didn't help.
Probably I need to tell whole story.
First, Qt-based application worked partionally: radio-button didn't work properly.
Moreover, when application launched, the foollowing message appeared:
(1) libEGL warning: DRI2: failed to authenticate
(2) QMetaObject::connectSlotsByName: No matching signal for on_radioButton_togleed(bool)
inotify_add_watch("home/pi/.config/qt5ct") failed. "No such file or directory"
Loooking for a solution for (1) I've found (certainly erroneously) this remedy:
https://pi3d.github.io/html/FAQ.html
$ sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so
$ sudo ln -fs /opt/vc/lib/libEGL.so /usr/lib/arm-linux-gnueabihf/libEGL.so.1
$ sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so
$ sudo ln -fs /opt/vc/lib/libGLESv2.so /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2
After applying these commands Qt-based application doesn't start ... and above-mentionned error announcing abscence of libGLESv2.so library appears
swampdog
Sat Apr 20, 2019 8:39 pm
$ apt-file search /opt/vc/lib/libGLESv2.so
libraspberrypi0: /opt/vc/lib/libGLESv2.so
$ apt-file search /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2.0.0
libgles2-mesa: /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2.0.0
The files are different on my rpi.
Hint for figuring it out..
sudo apt-get install apt-file mlocate
sudo updatedb #man locate
sudo apt-file update #man apt-file
Looks like you best revert those changes. There's actually a third libGLESv2 on the above rpi (for chromium)..
$ locate libGLESv2.so
/usr/lib/chromium-browser/libGLESv2.so
Return to “C/C++”
