brufra
Compute Module 3+ SDIO1 pins 22-27 and 34-39
Thu Apr 11, 2019 2:50 pm
I'm trying to handle the SDIO1 interface.
First of all, I used SDIO1 peripheral on pins 22-27 at 3.3 V by adding
dtoverlay=sdio,pool_once=off,bus_width=4
to config.txt file and it works fine.
Then, I tryied to use SDIO1 on pins 34-39 at 3.3V by:
  • creating a custon sdio34.dtbo file
  • copying it to the overlays folder
  • adding
    dtoverlay=sdio34,pool_once=off,bus_width=4
This second solution does not works, the error returned is
mmc1: error -110 whilst initialising SDIO card
Any advice?
Does SDIO supports 1.8V?
Thanks.
brufra
Return to “Compute Module”
