RogerW
Low voltage detection
Mon Apr 08, 2019 2:25 pm
If the processor detects a low supply voltage a lightning symbol is shown on the screen. I have a battery powered robot using a pi zero W with no screen. Is there a way my program can recieve an interrupt or other indication that the voltage is low.
klricks
Re: Low voltage detection
Tue Apr 09, 2019 2:42 am
There probably is but the voltage regulator in the powerbank tends to hold the voltage to 5V for as long as possible then suddenly drop out. In order to be useful you would need to add circuits to monitor the actual battery voltage.
LdB
Tue Apr 09, 2019 4:40 am
That is essentially what is done here using a simple ADC
https://raspi.tv/2013/controlled-shutdo ... -cell-lipo
RogerW
Wed Apr 10, 2019 10:59 am
Thanks for the comments. In fact I am more concerned by transients which may in fact be unlikely. I have four cells which deliver a nominal 6 volts. The motors are driven from this via an H bridge. The pi is fed from an up/down regulator supplied from the same source so SHOULD be ok but I wanted to be sure.
Since there is provision for user programs to monitor CPU temperature you would think it should be possible to trap out of spec voltage.
Wed Apr 10, 2019 11:05 am
The output of "vcgencmd get_throttled" will give information about the power state.
It reports if the Pi is currently slowed down because it is too hot, if the voltage is too low, or if any of these events have occurred at any time since power on.
RogerW
Wed Apr 10, 2019 1:42 pm
Thanks for that. It would be nice to get that information directly from a program but I cannot find any mention of such. Do you know how vcgencmd gets its data?
Wed Apr 10, 2019 2:08 pm
It talks to the VideoCore part of the GPU. Secret magic, I'm afraid.
RogerW
Wed Apr 10, 2019 2:13 pm
Fair enough. Thanks for the information.
DarkElvenAngel
Fri Apr 26, 2019 5:07 am
You can talk to the VideoCore directly with the mailbox protocol and get values directly. Documents are not so easy to find and are far from complete.
You will have an easier time opening a pipe and running vcgencmd and then use fscanf to convert the output to a variable you can use.
If you're interested in the mailbox here's a link https://github.com/raspberrypi/firmware ... -interface
RogerW
Fri Apr 26, 2019 8:52 am
Thanks for that information. Because I wanted to detect transient low voltage blips I was hoping for an "interupt" type of solution rather than polling. I have now decided it is not worth pursuing unless it definitely proves to be a problem which I supect is unlikely.
DarkElvenAngel
Mon Apr 29, 2019 2:58 am
I did a little more digging because I am interested in this problem and I found a few more things out. Low voltage detect is a GPIO Input known as PWR_LOW_N.
There's also an entry in /sys/devices/platform/soc/soc:firmware/get_throttled
and a kernel event that gets logged.
So far though I had no luck finding a way to generate a callback from these maybe someone else does.
Reference link.
https://github.com/raspberrypi/linux/issues/2367
Return to “C/C++”
