akash4720
Segmentation fault
Sun Apr 07, 2019 2:59 pm
Successfully compiled Code..
When i run this Code ..
One Led light blinking..
then Showing Segmentation fault
#include<wiringPi.h>
#include <wiringSerial.h>
#include<stdio.h>
#include <string.h>
#define RS 11
#define EN 10
#define D4 6
#define D5 5
#define D6 4
#define D7 1
#define led1 23
#define led2 24
#define led3 25
#define led5 14
#define buzz 7
#define in1 21
  int sp ;
  int count1=0,count2=0,count3=0;
  char ch;
  char rfid[13];
  int i=0;
  char temp[5];
  void check_button();
  void lcdcmd(unsigned int ch)
    int temp=0x80;
    digitalWrite(D4, temp & ch<<3);
    digitalWrite(D5, temp & ch<<2);
    digitalWrite(D6, temp & ch<<1);
    digitalWrite(D7, temp & ch);
    digitalWrite(RS, LOW);
    digitalWrite(EN, HIGH);
    delay(10);
    digitalWrite(EN, LOW);
    digitalWrite(D4, temp & ch<<7);
    digitalWrite(D5, temp & ch<<6);
    digitalWrite(D6, temp & ch<<5);
    digitalWrite(D7, temp & ch<<4);
    delay(10);
    void write(unsigned int ch)
    int temp=0x80;
    digitalWrite(RS, HIGH);
    delay(10);
    delay(10);
  void clear()
     lcdcmd(0x01);
  void setCursor(int x, int y)
    int set=0;
    if(y==0)
    set=128+x;
    if(y==1)
    set=192+x;
    lcdcmd(set);
  void print(char *str)
    while(*str)
     write(*str);
     str++;
  void begin(int x, int y)
    lcdcmd(0x02);
    lcdcmd(0x28);
    lcdcmd(0x06);
    lcdcmd(0x0e);
    lcdcmd(0x01);
 void buzzer()
     digitalWrite(buzz, HIGH);
     delay(1000);
     digitalWrite(buzz, LOW);
void wait()
     digitalWrite(led5, LOW);
     delay(3000);
  void serialbegin(int baud)
    if ((sp = serialOpen ("/dev/ttyS0",baud)) < 0)
     clear();
     print("Unable to open");
     setCursor(0,1);
     print("serial Port");
  void setup()
   if (wiringPiSetup () == -1)
     clear();
     print("Unable to start");
     setCursor(0,1);
     print("wiringPi");
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led5, OUTPUT);
  pinMode(buzz, OUTPUT);
  pinMode(RS, OUTPUT);
  pinMode(EN, OUTPUT);
  pinMode(D4, OUTPUT);
  pinMode(D5, OUTPUT);
  pinMode(D6, OUTPUT);
  pinMode(D7, OUTPUT);
  pinMode(in1, INPUT);
  digitalWrite(in1, HIGH);
  begin(16,2);
  serialbegin(9600);
void get_card()
   digitalWrite(led5, HIGH);
   i=0;
   while(i<12)
      check_button();
       while(serialDataAvail (sp))
        ch= serialGetchar(sp);
        rfid[i]=ch;
        fflush (stdout) ;
        i++;
   rfid[i]='\0';
  buzzer();
   return;
void main()
   setup();
   clear();
   print("Attendance Systm");
   setCursor(0,1);
   print("using RPI ");
   delay(2000);
   clear();
   print("Circuit Digest");
   setCursor(0,1);
   print("Welcomes you");
   delay(2000);
   clear();
   print("System Ready");
   delay(1000);
   clear();
   while(1)
        clear();
        print("Place Your Card:");
        get_card();
        setCursor(0,1);
        print(rfid);
        delay(1000);
        if(strncmp(rfid,"0900711B6003",12)==0)
           count1++;
           clear();
           print("Attd. Registered");
           setCursor(0,1);
           print("Student 1");
           digitalWrite(led1, HIGH);
           buzzer();
           digitalWrite(led1, LOW);
           wait();
        else if(strncmp(rfid,"090070FE6EE9",12)==0)
           count2++;
           clear();
           setCursor(0,1);
           print("Student 2");
           digitalWrite(led2, HIGH);
           buzzer();
           digitalWrite(led2, LOW);
           wait();
          else if(strncmp(rfid,"3F0072C049C4",12)==0)
           count3++;
           clear();
           setCursor(0,1);
           print("Student 3");
           digitalWrite(led3, HIGH);
           buzzer();
           digitalWrite(led3, LOW);
           wait();
        else
        clear();
           print("Invalid Card");
           buzzer();
           buzzer();
           wait();
void check_button()
   if(digitalRead(in1)==0)
           clear();
           setCursor(0,0);
           print("std1  std2  std3");
           setCursor(1,1);
           sprintf(temp,"%d",count1);
           print(temp);
           setCursor(7,1);
           sprintf(temp,"%d",count2);
           print(temp);
           setCursor(13,1);
           sprintf(temp,"%d",count3);
           print(temp);
           delay(5000);
           clear();
StuartF
Re: Segmentation fault
Sun Apr 07, 2019 5:09 pm
There are two check_button() functions being defined.
One is empty, just above 'void lcdcmd(unsigned int ch)'.
This may be the cause of the problem, however try using gdb to debug.
jahboater
Sun Apr 07, 2019 6:26 pm
Also make sure it compiles cleanly with these options in addition to your usual ones:
-Wall -Wextra -Wconversion -Wuninitialized
Sun Apr 07, 2019 7:14 pm
StuartF,
No, there are not.
check_button is mentioned 3 times. Firstly as a forward declaration, then as a call, then as the actual function definition.
This is all quite normal although I would prefer to remove the forward declaration and move the definition up to the top.
Paeryn
Sun Apr 07, 2019 9:43 pm
Your main error is in get_card()
void get_card()
  i=0;
  while(i<12)
    check_button();
      rfid[i]=ch;
      fflush (stdout) ;
      i++;
  rfid[i]='\0';
  buzzer();
  return;
Your inner while loop will keep reading for as long as there is data from the serial port, if there are more than 12 then you'll overrun the array rfid. Also the condition for that inner while loop can cause problems as if there is an error reading from the serial then serialDataAvail() will return -1 which will keep the while loop running.
I assume this is what is causing the segfault, it does on mine, the serial setup fails and although you check for that and print a message on your LCD you carry on regardless trying to use it.
Please note that my name doesn't start with the @ character so can people please stop writing it as if it does!
Return to “C/C++”
