Mattyhawk
Raspberry Pi powered RC car
Fri Apr 05, 2019 8:27 pm
I am planning on putting a raspberry pi 3a+ into an rc car and adding various sensors to it. I already have the raspberry pi with Ubuntu mate (bionic 18.04.2 - https://ubuntu-mate.org/download/) downloaded onto it and have the os up and running. I am planning on putting ROS(robot os) onto it to control the RC car (preferably this one - https://www.argos.co.uk/product/2462732). I will then use the raspberry pi camera and an ultrasonic sensor to allow it to understand its surroundings
So I have 2 questions:
1. Do you think this project will work?
2. Which motor controller board would you recommend to control the motors on the RC car.
pcmanbob
Re: Raspberry Pi powered RC car
Sat Apr 06, 2019 9:23 am
I don't see why not as long as there is room for your pi and its power supply/battery and the car is capable of moving with the extra weight once everything is attached.
I would do some testing before deciding on a motor controller as you don't know the current draw of the motor, I would test its stall current using rechargeable batteries and then look for a motor controller rated for that current, you will want one with a low internal volt drop as the motor is probably only 6v so an L298N may not be the most suitable.
