pearcecg
New official keyboard - RISCOS
Thu Apr 04, 2019 11:40 am
Why does the new keyboard fail to give the correct upper case characters (SHIFT) ?
I've discovered I can correct this behaviour with (CTRL-SHIFT-NUMLOCK). But why should I have to do this on every boot?
Is there some way of getting it to behave normally?
I'm mainly using RISC OS by the way.
Charles Pearce
jahboater
Re: New official keyboard
Thu Apr 04, 2019 11:54 am
FYI, it works perfectly with Gentoo64, and I would put money on it working perfectly with Raspbian (since the RPF will have tested it the most on that).
Is there some setting within RISC-OS that you could tweak?
PiGraham
Thu Apr 04, 2019 12:04 pm
Charles Pearce
It sounds like Numlock is on by default which makes sense for keyboards with separate number pads but not for this keyboard. It is on Windows anyway. Just press NUMLOCK to toggle it. You don't need CTRL-SHIFT.
It would be good to have control over that.
It seems there is a solution for Rasbian. I don't know about RISC OS.
viewtopic.php?t=10081
Thu Apr 04, 2019 12:05 pm
Charles Pearce
The Raspberry Pi Foundation / Raspberry Pi Trading only support Raspbian Operating System, therefore that is the operating they will use for testing, if it is a RiscOS issue then suggest you report to the developers:
https://www.riscosopen.org/content/down ... spberry-pi
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Stretch.
PiGraham
Re: New official keyboard - RISCOS
Thu Apr 04, 2019 12:28 pm
This isn't anything specific to thePi keyboard. You just need to set the numlock default state as you want it. The only difference with this keyboard is that the num pad is not separate but shares keys so you want numlock off by default instead of on.
This may help for RISC OS
http://www.riscos.com/support/users/con ... /input.htm
pearcecg
Thu Apr 04, 2019 2:00 pm
Thanks for this
NUMLOCK now sorted. - I should have known this!
Return to “RISCOS”
