Logic Error
Pi zero appears dead
Mon Apr 01, 2019 7:53 pm
The other day I was given a pi zero, I've got noobs on an 8gb sd card, I purchased a power supply but I'm getting no lights on the pi and no output on the tv I'm using
Andyroo
Re: Pi zero appears dead
Wed Apr 03, 2019 1:20 am
It’s remotely possible that the LEDs are dead - you could check the voltage out on the GPIO but to be honest I think you are looking at the $35 dollar fix discounted down fir a Zero W :cry: esp if you are not seeing anything at all on the monitor.
Imperf3kt
Wed Apr 03, 2019 2:32 am
The Pi Zero range only has an ACT LED (green) , no power good LED (the red one).
The ACT LED won't blink unless there is activity on the SD card.
How old is the version of NOOBS on the card? It may be too old to work on a Pi Zero.
I recommend using etcher to install the latest version of Raspbian Stretch full and completely ignore NOOBS.
You will require at least some other kind of device to flash the SD card that is at least SDHC compatible.
55:55:44:44:4C
52:4C:52:42:41
Wed Apr 03, 2019 6:18 am
viewtopic.php?f=28&t=58151
Logic Error
Wed Apr 03, 2019 8:51 pm
Got noobs less than a week ago so it can't be outdated
Imperf3kt
Wed Apr 03, 2019 10:23 pm
Was the Pi Zero you were given brand new, or second hand?
Perhaps the previous owner damaged it?
Take a look through the boot sticky and see if anything in there helps.
viewtopic.php?t=58151
If not, try to power the Pi without an SD card inserted. If it generates heat from the big black chip, it has been electronically damaged and cannot be repaired. (since replacement parts are not available and the required tools are extremely expensive)
55:55:44:44:4C
52:4C:52:42:41
B.Goode
Wed Apr 03, 2019 10:33 pm
Your download of NOOBS may be current, but you may not have written it to your microSD card correctly. Or your microSD card might be faulty.
Or the RPiZero might be faulty: was it passed on to you on the understanding that it was in working order, or simply "as seen"?
You have been referred to a summary of all the knowledge accumulated from these forums during the past 7 years about difficulties getting an RPi to boot, see - STICKY: Is your Pi not booting? (The Boot Problems Sticky) - viewtopic.php?f=28&t=58151
What was the outcome of the test proposed there for determining whether an RPi Zero is functional?
Logic Error
Fri Apr 05, 2019 7:19 pm
Computer has detected it👍
It was given to me brand new
Don't think there was any heat, but it's a hard to tell cos my hands are cold, but a 2nd opinion said no
Imperf3kt
Sat Apr 06, 2019 4:41 am
If you're unsure about the heat we mentioned then it's fine.
The usual "dead SOC" heat will burn your finger after a couple of seconds - you'd know without a doubt if it was getting hot.
Do that just leaves the SD card. Either it wasn't flashed right, or something else has happened.
55:55:44:44:4C
52:4C:52:42:41
Logic Error
Tue Apr 09, 2019 1:05 pm
All good, thx for the help
Re installed without noobs on a different sd card
All working nowImage
Return to “Beginners”
