MaximilianSchmitt
VNC isn't working
Sat Mar 23, 2019 6:35 am
After installing a graphical interface on the RaspberryPi I wanted to set up VNC. I had forgotten that "raspi-config" should actually offer that, but it was no longer displayed in my menu.
I typed:
sudo apt-get install vnc4server vnc-java
sudo apt-get install xfonts-base
sudo vncpasswd
vncserver
According to the console "raspberrypi: 1 (pi)" was started on the desktop.
It is also a port opened:
tcp        0      0 127.0.0.1:5901          0.0.0.0:*               LISTEN
Why can not I access the RaspberryPi? I have tried several viewers.
Andyroo
Re: VNC isn't working
Sat Mar 23, 2019 8:29 am
Do you have a monitor / keyboard / mouse attached to the Pi?
If not - can you pop them on and try again? Strange request but I just want to double check some advice I’ve been giving out is still valid and I’m stuck for kit again as my daughter is here (eats, sleeps, borrows bits - such is daddy’s girls role in life)
Sat Mar 23, 2019 9:35 am
I typed:
sudo vncpasswd
vncserver
If you are running Raspbian Stretch you ideally should use RealVNC:
https://www.realvnc.com/en/raspberrypi/
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
MaximilianSchmitt
Sat Mar 23, 2019 6:57 pm
RealVNC works :)
I thank you
