Simple
Contact: YouTube
Raspberry Pi3 project using GPIO and LEDs
Thu Mar 21, 2019 9:33 pm
Hello and thank you
I have a project using the RPi3 and GPIO pins for a project..
I put together a flow chart, but not sure if I drew it the right way.
Any pointers/help appreciated.
See attached
pcmanbob
Re: Raspberry Pi3 project using GPIO and LEDs
Fri Mar 22, 2019 10:32 am
So your flow chart may not be drawn correctly but its understandable , so what exactly do you want help with ?
B.Goode
Fri Mar 22, 2019 11:06 am
If this is simply your own personal project the flowchart or other design tool is simply an aid to help you understand the problem and its solution clearly. You can be the judge of that.
If this is for a marked or assessed assignment for work or a course of study then it will be important to use symbols that meet any relevant standards. Your use of the same shaped nodes for both decisions and actions does not look like any flowchart standard I have encountered. But if it meets your requirements my opinion and experience are irrelevant.
Simple
Contact: YouTube
Fri Mar 22, 2019 11:44 am
Well, I've started and played around with gpiozero and some of the examples to levels of success, I can make LEDs do some stuff, but can't seem to get much farther than modifying the examples. I can make a LED steady or blink based on an input, but not change color and blink or steady. In the examples there's also some simple code to check for a connection to the web, but I would like to modify that to just check for a network connection since my project may be used on a lan without a web connection. I will probably make this into two separate programs, one for the LEDs and one for the gpio switching, for sake of personal ease. Usually I make discreet circuits for everything I need and would be simple, but this seemed simple enough to tackle with potentially just a few lines of code and would have some potential for changes and additions in the future.
Thank you
pcmanbob
Fri Mar 22, 2019 11:59 am
So to answer some of your points .
To make an LED change colour you need to use an LED that actually has 2 or 3 LED's built in to one package , you then switch each colour on or off to get the different colours.
example of using 3 colour LED https://www.instructables.com/id/Using- ... n-RGB-LED/
To make your check for a connection to the web code work using just a local network all you need to do is substitute the router address in place of the web address you were using to test to.
So you may have been using google.com for example so to make it just test for a local connection you would substitute the IP of the router which might be for example 192.168.1.1 or 192.168.0.1
if you share the code you are using than may be we can help with the changes you need.
please when posting code use code tags
Add [code] at the top
code goes here
and [/code] at the bottom.
Edit Oops posted wrong link corrected now thanks B.Goode for spotting my mistake
B.Goode
Fri Mar 22, 2019 12:25 pm
example of using 3 colour LED https://www.hackster.io/windowsiot/rgb- ... ple-729ea7
Since you are presumably using the Raspberry Pi Foundation recommended and supported Raspbian Operating System it might be less confusing to continue with gpiozero rather than switching to an alternative Operating System.
To switch between one of several single-colour LEDs, see Section 2.9 here: https://gpiozero.readthedocs.io/en/stab ... l#ledboard
To control a 3-colour RGB LED see 2.16 here: https://gpiozero.readthedocs.io/en/stab ... -color-led
Simple
Contact: YouTube
Fri Mar 22, 2019 3:14 pm
Hi and thank you
Yes I am using a RGB led
I can make this do basic things, but I can't figure out how to in this case, turn the gled off, then the bled on.
I can make them pulse or blink or whatever, but not switch. I get a cyan color. I've taken some shots at "button.when_released = bled.on gled.off" to no avail.
In reference to the checking for a network connection, In my case, I won't be able to tell what the router address will be. The system (raspbian lite based) will be connected to unknown networks. I suppose there could be three states, one being 'blink while no network present' 'pulse while connected to a network' and 'steady when network has web access'. That would work.
Note: I am using in the below example, GPIO23 for my sensing input versus the GPIO22 in the above flow chart because I get errors using the below code with GPIO22. I have connected GPIO22 to GPIO23 to sense the signal if high or low. I would prefer to sense directly the state of GPIO22, however haven't discovered a method to do so without getting errors.
Thank You
from gpiozero import PWMLED, Button
from signal import pause
rled = PWMLED(24)
gled = PWMLED(25)
bled = PWMLED(26)
button = Button(23, pull_up=False)
button.when_held = gled.on
pause()
Forris
Raspberry Pi Certified Educator
Fri Mar 22, 2019 3:41 pm
It's great that you seem to understand the problem, and a possible solution, so let's see if I can help. Now I'm no expert on Python but the problem is that 'button.when_released = bled.on gled.on' is trying to call two functions, which can't be done on one line.
The simplest way around this is to create two new functions, one to do 'blue on, green off' and one to do the opposite. Eg:
def blue_on():
    bled.on()
    gled.off()
def green_on():
    gled.on()
    bled.off()
Now those lines should read :
button.when _held = green_on
button.when_released = blue_on
Hope that makes sense :-)
Simple
Contact: YouTube
Fri Mar 22, 2019 4:47 pm
Hey thanks
Making some headway. That code works, just one correction
button.when_held = green_on
I'll have to play around with it and see what I can do
What would I be looking for in adding the web status functionality?
Setting it up for monitoring the status of GPIO22 from GPIO23 seems simple enough now, although I would like to monitor GPIO22 directly, what would I do to add another layer of conditions for that and router/web checking? Should I stick to just pinging google?There are a number of ways of checking network connections, although I wouldn't know how to integrate it into this project.
I would imagine that I would set it up to check for the web first, then condition for the GPIO. Tips on how to combine the conditions of web presence with GPIO status?
Thanks again
S
pcmanbob
Fri Mar 22, 2019 6:18 pm
I know this is an old project page but the code it uses is still valid and is an example of how to integrate network checking with led outputs.
https://www.instructables.com/id/Raspbe ... t-Monitor/
Simple
Contact: YouTube
Fri Mar 22, 2019 8:18 pm
Thanks Bob
That looks like the angle necessary for making it work, have the network start a process, or send a signal. I may just keep it simple first, just pinging Google or similar, until the rest is working with it. At this point, I need to discover how to integrate the LED indication with gpio changes AND web status. I think if I can get that sorted, then I may be able to infer most of the rest. Hopes
Thanks again, really appreciate the help here
S
ben_nuttall
Sun Mar 24, 2019 12:08 pm
Use PingServer and LED or PWMLED in GPIO Zero:
https://gpiozero.readthedocs.io/en/stab ... t.html#led
https://gpiozero.readthedocs.io/en/stab ... tml#pwmled
https://gpiozero.readthedocs.io/en/stab ... pingserver
led.blink() # on / off every second
led.blink(2, 2) # on/off every 2 seconds
pwmled.pulse() # fade in/out every second
pwmled.pulse(2, 2) # fade in/out every 2 seconds
pingserver.is_active # True/False based on ping status
Example: when the internet is connected, the green led is on, when it's not, the red led pulses:
from gpiozero import LED, PWMLED, PingServer
from time import sleep
red = PWLED(2)
green = PWMLED(3)
network = PingServer('google.com')
while True:
    if network.is_active:
        green.on()
        red.off()
    else:
        red.pulse()
        green.off()
     sleep(30)
Former RPF staff. Author of gpiozero and creator of piwheels.
Simple
Contact: YouTube
Sun Mar 24, 2019 4:07 pm
Thanks Ben
There were a few typos, but thank you
At the moment, I am looking at https://gpiozero.readthedocs.io/en/stab ... ng-sources for the ability to have both the functionality of a steady (web) or blinking (noweb) blue LED, if GPIO22 is not active, and a steady (web) or blinking (noweb) green LED, if GPIO22 is active. My red LED is reserved at the moment for something more catastrophic in nature. I suppose I could also shelve for the time being, web status indication, in favor of more important functionality, although, being able to tell if the web is present, headless, is an important indicator for everyday troubleshooting and confirmation. Usually I would wire up a circuit that takes care of everything, however, I would like to experiment with the ability to code this feature and be able to change it around with some simple lines in code if I don't like it or want to have more/better. It's probably going to take some time for me to read through the docs and play with the code enough to make something beta. It's common for me to do things in enough ways to become knowing before I call it done. I'm slowly getting to know and recognize how things go together in GPIO0. I like how you offer multiple ways of looking at the challenges.
S
Simple
Contact: YouTube
Mon Mar 25, 2019 2:35 pm
Hello again
Is there an equivalent to this function from RPi.GPIO
This is something that I would like to do and am wondering if I would be better off working with RPi.GPIO
import RPi.GPIO as GPIO
channel = 11
# Setup your channel
GPIO.setup(channel, GPIO.OUT)
GPIO.output(channel, GPIO.LOW)
# To test the value of a pin use the .input method
channel_is_on = GPIO.input(channel)  # Returns 0 if OFF or 1 if ON
if channel_is_on:
    # Do something here
B.Goode
Mon Mar 25, 2019 2:52 pm
Looking for an equivalent in gpiozero?
See 13.1.1 https://gpiozero.readthedocs.io/en/stab ... tml#button
channel_is_on = button.is_pressed
seems to be similar?
pcmanbob
Mon Mar 25, 2019 3:12 pm
Just tried to set an output using LED in gpiozero and then read its state using Button set to the same pin to read the LED state, causes an error because the pin is already in use by LED when the Button set up is attempted.
B.Goode
Mon Mar 25, 2019 3:40 pm
See another recent thread by this user. Maybe you can be paid for your efforts.
ben_nuttall
Mon Mar 25, 2019 4:34 pm
Why?
ben_nuttall
Mon Mar 25, 2019 4:36 pm
You're trying to use an LED object to light an LED, and then a Button object on the same pin to check whether the LED is on? Don't do that.
You can check if an LED is on using led.is_lit:
led = LED(2)
led.blink()
while True:
    if led.is_lit:
        print("on")
    else:
        print("off")
    sleep(1)
pcmanbob
Mon Mar 25, 2019 5:00 pm
Ben
I don't know what the OP is going to use as the output , my test was simple to prove you could not do it in the same way as you would with RPi.GPIO were you set a pin as output but still read its state using a GPIO.input command.
you example looks to be what he wants if he uses LED , can this be used with other output drivers ?
Simple
Contact: YouTube
Mon Mar 25, 2019 6:14 pm
Hello and thank you again
What I have is a DAC that unmutes itself using a GPIO pin GPIO22, so that pin is reserved and functions via it's own driver, aside of anything here in this post. What I would like to to is read that pin internally if possible, rather than connecting another pin to it to read from (which I have done using GPIOzero). I had the same errors as above in attempting to use that technique. I don't know enough about these systems and various layers to know which method is the best. From reading around, I began to wonder if I need an more granular direction, as I assume that GPIOzero is more of a general layer. I dont know. And yes I am up for offering $ for assistance.
To reiterate..
System comes up then
If ever GPIO22 low and
No web then Blink bLED
Yes web then On bLED
If ever GPIO22 high and
No web then Blink gLED
Yes web then On gLED
My other part of the project (which I presume can be constructed as a separate process and program) is to also detect if GPIO22 is high, then run a short delay, say half second, then activate a relay (high out) on GPIO23, then disable the relay if GPIO22 is ever not high.
Simple
Contact: YouTube
Mon Mar 25, 2019 7:26 pm
Additionally,
I like the when_held method over the when_pressed in that it eliminates the possibility of getting on the wrong side (opposite functioning) of an edge based method.
Return to “Python”
