wongzlll
Pitch, roll-raspberry pi; python
Sun Mar 17, 2019 2:54 am
1. You will now move the marble on the board by detecting the roll and pitch of the board. You would have observed that while the marble is moving according to the tilt of the board, it leaves a trail of its movement along the path.
This is my code:
from sense_hat import SenseHat
from time import sleep
sense = SenseHat()
b = (0, 0, 0)
w = (255, 255, 255)
board = [[b,b,b,b,b,b,b,b],
[b,b,b,b,b,b,b,b],
[b,b,b,b,b,b,b,b],
[b,b,b,b,b,b,b,b],
[b,b,b,b,b,b,b,b],
[b,b,b,b,b,b,b,b],
[b,b,b,b,b,b,b,b],
[b,b,b,b,b,b,b,b] ]
y=2
x=2
board[y][x]=w
board_1D=sum(board,[])
print(board_1D)
sense.set_pixels(board_1D)
def move_marble(pitch,roll,x,y):
  new_x = x #assume no change to start with
  new_y = y #assume no change to start with
  if 1 < pitch < 179 and x != 0:
    new_x -= 1 # move left
  elif 359 > pitch > 179 and x != 7:
    new_x += 1 # move right
  if 1 < roll < 179 and y != 7:
    new_y += 1 # move up
  elif 359 > roll > 179 and y != 0:
    new_y -= 1 # move down
  return new_x, new_y
while True:
  pitch = sense.get_orientation()['pitch']
  roll = sense.get_orientation()['roll']
  x, y = move_marble(pitch, roll, x, y)
  board[y][x] = w
  print("pitch {0} roll {1}".format(round(pitch,0), round(roll,0))
  sleep (0.05)
2. You will now add boundary walls on the board that the marble cannot cross. A simple boundary wall can be as follows, which is defined by using red colour pixels.
This is my code added on to the above code(or should i do it separately?):
r = (255, 0, 0)
board = [[r,r,r,r,r,r,r,r],
[r,b,b,b,b,b,b,r],
[r,b,b,b,b,b,b,r],
[r,b,b,b,b,b,b,r],
[r,b,b,b,b,b,b,r],
[r,b,b,b,b,b,b,r],
[r,b,b,b,b,b,b,r],
[r,r,r,r,r,r,r,r] ]
def check_wall(x,y,new_x,new_y):
  if board[new_y][new_x] != r:
    return new_x, new_y
  elif board[new_y][x] != r:
    return x, new_y
  elif board[y][new_x] != r:
    return new_x, y
  else:
    return x,y
  new_x = x
  new_y = y
    new_x -= 1
    new_x += 1
    new_y += 1
    new_y -= 1
  new_x,new_y = check_wall(x,y,new_x,new_y)
  return new_x, new_y
3. Add the new function check_wall() to your program. Execute the program and observe that the marble will only move within the boundary and cannot cross the wall as you tilt the board. To complete the game, you will now add a target in your maze design, such as by using a green color to indicate its location as shown below. Modify your program and add the necessary code that will terminate the game once the target is captured by the Marble.
This is my code(do i add on or do it separately?):
board = [[r,r,r,b,b,b,b,r],
[r,b,b,b,b,b,b,r],
[b,b,b,b,b,r,b,r],
[b,r,r,b,r,r,b,r],
[b,b,b,b,b,b,b,b],
[b,r,b,r,r,b,b,b],
[b,b,b,r,b,b,b,r],
[r,r,b,b,b,r,r,r] ]
    return new_x, new_y
    return x, new_y
    return new_x, y
  else:
    return x,y
g = (0, 255, 0)
[r,b,b,b,b,b,b,r],
[b,b,b,b,g,r,b,r],
[b,r,r,b,r,r,b,r],
[b,b,b,b,b,b,b,b],
[b,r,b,r,r,b,b,b],
[b,b,b,r,b,b,b,r],
[r,r,b,b,b,r,r,r] ]
while not game_over:
  x,y = move_marble(pitch,roll,x,y)
  if board[y][x] == g:
    sense.show_message("Win")
    game_over = True
  board [y][x] = w
  sense.set_pixels(sum(board,[]))
  sleep(0.05)
  board[y][x] = b
sense.show_message('yay!!')
Thank you!
[moderator added code tags, please do so yourself next time!]
scotty101
Re: Pitch, roll-raspberry pi; python
Mon Mar 18, 2019 2:45 pm
Is there a question? Or are you just posting your code?
Return to “Python”
