gytisg
onoff : fs.existsSync is not a function
Sat Mar 16, 2019 9:37 pm
I am working on a Pi project with onoff, Node and Vue. Have been trying to implement a simple LED switch using this code :
etOutput : function(){
var Gpio = require('onoff').Gpio; //include onoff to interact with the GPIO
var LED = new Gpio(4, 'out'); //use GPIO pin 4, and specify that it is output
var blinkInterval = setInterval(blinkLED, 250); //run the blinkLED function every 250ms
function blinkLED() { //function to start blinking
  if (LED.readSync() === 0) { //check the pin state, if the state is 0 (or off)
    LED.writeSync(1); //set pin state to 1 (turn LED on)
  } else {
    LED.writeSync(0); //set pin state to 0 (turn LED off)
function endBlink() { //function to stop blinking
  clearInterval(blinkInterval); // Stop blink intervals
  LED.writeSync(0); // Turn LED off
  LED.unexport(); // Unexport GPIO to free resources
setTimeout(endBlink, 5000); //stop blinking after 5 seconds
However, this gives me an error :
 ypeError: fs.existsSync is not a function
    at new Gpio (webpack-internal:///./node_modules/onoff/onoff.js:94)
    at VueComponent.setOutput (webpack-internal:///./node_modules/babel-loader/lib/index.js!./node_modules/vue-loader/lib/selector.js?type=script&index=0!./src/components/HelloWorld.vue:88)
    at invokeWithErrorHandling (webpack-internal:///./node_modules/vue/dist/vue.esm.js:1862)
Pi is updated and LED works just fine using a python script. I also tried other npm libraries like pigpio and rpi-gpio but received similar / same errors. Am I missing something?
Thanks,
Gytis
Andyroo
Re: onoff : fs.existsSync is not a function
Sat Mar 16, 2019 11:53 pm
The fs.existsSync has been / is being deprecated going by https://node.readthedocs.io/en/latest/a ... tssyncpath. I cannot tell the date of the docs as the ‘about’ does not exist...
You either have an old code block (that calls it) or something that’s too new (has removed it).
Not that that helps you fix you problem :cry:
Return to “Advanced users”
