hmh7
Sending Commands to a raspberry pi
Sat Mar 16, 2019 9:34 am
Hello World,
I wanted to ask if it is possible to send commands to the raspberry pi remotely using python. I did lots of search and couldn't find anything similar to what I want.
I want to send commands such as gweb and mv.
Regards
Andyroo
Re: Sending Commands to a raspberry pi
Sat Mar 16, 2019 12:18 pm
Best thing is to use MQTT to link machines together and have your Python program receive these and act on them - the program can check that the command is in a limited list and ignore those that are not.
Giving anything access (especially root access) to a machine is very dangerous for network security.
A good coverage of Python MQTT is at http://www.steves-internet-guide.com
thagrol
Sat Mar 16, 2019 12:19 pm
In brief, and assuming the machine running your python code has ssh client installed:
  • Set up key based login
  • In your code use somthing like
    os.system('ssh user@host command')
Arguing with strangers on the internet since 1993.
ghp
Sat Mar 16, 2019 2:22 pm
fabric2 allows to execute commands on a remote machine.
https://pypi.org/project/fabric2
or consider thrift. https://thrift.apache.org/
it allows to execute methods in a remote python (or c, java, ...) application.
Sankalp sharma
Sat Mar 16, 2019 3:15 pm
You can remotely access it by ssh and vnc server and can make changes as well :D as run commands
Return to “Python”
