Diccon
Automating setup of midi piano
Tue Mar 12, 2019 11:31 pm
This is my first project with my Pi 3 B+.
I have a USB Piano Keyboard that i want to use with my Pi. I have gt it working using Fluidsynth and then connecting the ports using aconnect is a separate terminal widow.
I now want to automate the setup so that my children can just switch it on.
To do this I have added script to the global autostart file.
#!/bin/bash/sh
fluidsynth -is --audio-driver-alsa --gain 3 /usr/share/sounds/sf2/FluidR3_GM.sf2
wait(30)
aconnect 20:0 128:0
I know that fluidsynth is loading as the client appears when I run aconnect -o
Thak you
tvjon
Re: Automating setup of midi piano
Thu Mar 14, 2019 9:48 am
Thak you
I imagine they'll be really pleased with your project.
What name shows up for your usb midi keyboard via:
aconnect -o
& which "global autostart file" would that be?
Unzip the attached small application, & run it from a terminal thus:
$ ./keysynth /usr/share/sounds/sf2/FluidR3_GM.sf2 The_name_of_your_Keyboard
All being well, you can put that line in your script, eg., this is the one I currently use, although not autostarting.
#!/bin/bash/sh
./keysynth /usr/share/sounds/sf2/8MBGMSFX.SF2 Uno
tvjon
Thu Mar 14, 2019 9:54 am
Thak you
aconnect -o
#!/bin/bash/sh
OOps, forgot to add the file.
keysynth.zip
(3.75 KiB) Downloaded 24 times
Diccon
Thu Mar 14, 2019 9:13 pm
Thank you, I will give that a go.
I have run the aconnect -o command and the keyboard appears on 20 and fluidsynth on 128. Once the system has booted up if I type aconnect 20:0 128:0 everything works which is how I know fluidsynth is loading properly.
The autostart file is /etc/xdg/lxsession/LXDE-pi/autostart
Thanks for the help
Diccon
Thu Mar 14, 2019 11:28 pm
The keyboard name on aconnect -o is miniKEY
Diccon
Thu Mar 14, 2019 11:35 pm
Sorry to be a pain.
I have loaded it onto the pie and I am getting
bash: ./keysynth: Permission denied
I am running from the Pi account.
Any ideas please?
Diccon
Fri Mar 15, 2019 12:18 am
I had another play and works perfectly including in the autostart file
Thank you
