Hello.
I'm trying to use the Android on my Rasp 3B+.
I'm using the Lineage 15.1 image to this. I have a problem when I try to write the image to the sd card.
After the writing process finished, it is created some partitions on the SD and the Android does not start when I insert the card in the Rasp.
I'm using the SD card formatter to format the sd card (sandisk 16 GB);
I tried to write the image with the win32 disk imager and the balenaEtcher. I have similar results with both softwares.
I tried to use the KonstaKANG version 20180706 and after the version 20180307. The same results for the both versions.
Between each attempt, I remove all the partitions from the sd; I create a new partition (entire); and format the sd again.
The rasp is ok because I have other sd card running rapbien ok.
Thanks,
Hisse!
