Why another Rasperry Pi Bluetooth Speaker tutorial ?
Because I could not find a reliable and up-to-date source to tell me how to proceed.
Because Bluez is real pain to configure.
My purpose here is hence to present a step-by-step consistent procedure to help anybody to turn its Raspberry Pi into a headless bluetooth speaker.
What follows has been tested on a Raspberry Pi 3 Model B Rev 1.2 running Raspbian Stretch Lite at the time of writing, i.e. March 9th, 2019.
Note : I choose pulseaudio and not alsa as I need to run and mix several applications in my car audio project.
2) Configuring Bluetooth as an A2DP Sink
We'll be needing pulseaudio and it's bluetooth module.
[email protected]:~ $ sudo apt-get install pulseaudio pulseaudio-module-bluetooth
For some unknown reason, we need to add our user to group lp (if anybody knows why, please tell me).
[email protected]:~ $ sudo usermod -a -G lp pi
[email protected]:~ $ newgrp lp
Let's make our Pi permanently discoverable as an A2DP Sink.
[email protected]:~ $ sudo nano /etc/bluetooth/main.conf
And add / uncomment / change
Class = 0x41C
DiscoverableTimeout = 0
[email protected]:~ $ sudo systemctl restart bluetooth
[email protected]:~ $ bluetoothctl
[NEW] Controller XX:XX:XX:XX:XX:XX raspberrypi [default]
[bluetooth]# power on
Changing power on succeeded
[bluetooth]# discoverable on
Changing discoverable on succeeded
[CHG] Controller XX:XX:XX:XX:XX:XX Discoverable: yes
[bluetooth]# pairable on
Changing pairable on succeeded
[bluetooth]# agent on
Agent registered
[bluetooth]# default-agent
Default agent request successful
[bluetooth]# quit
Agent unregistered
[DEL] Controller XX:XX:XX:XX:XX:XX raspberrypi [default]
We need to start pulseausio manually now.
[email protected]:~ $ pulseaudio --start
And now let's check if everything is OK.
[email protected]:~ $ sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2019-03-09 21:55:45 CET; 31s ago
Docs: man:bluetoothd(8)
Main PID: 2296 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─2296 /usr/lib/bluetooth/bluetoothd
Mar 09 21:55:45 raspberrypi systemd[1]: Starting Bluetooth service...
Mar 09 21:55:45 raspberrypi bluetoothd[2296]: Bluetooth daemon 5.43
Mar 09 21:55:45 raspberrypi systemd[1]: Started Bluetooth service.
Mar 09 21:55:45 raspberrypi bluetoothd[2296]: Starting SDP server
Mar 09 21:55:45 raspberrypi bluetoothd[2296]: Bluetooth management interface 1.14 initialized
Mar 09 21:55:45 raspberrypi bluetoothd[2296]: Failed to obtain handles for "Service Changed" characteristic
Mar 09 21:55:45 raspberrypi bluetoothd[2296]: Sap driver initialization failed.
Mar 09 21:55:45 raspberrypi bluetoothd[2296]: sap-server: Operation not permitted (1)
Mar 09 21:56:14 raspberrypi bluetoothd[2296]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSource
Mar 09 21:56:14 raspberrypi bluetoothd[2296]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2DPSink
And it is ! Bluetooth is up and running and A2DP is registered.
At this stage, you should be able to see you Pi as an A2DP Source/Sink from your mobile bluetooth menu.
Let's go for a quick test. Try to connect to your Pi. You should be able to pair but you can't connect. Your device must be trusted first. Let's do it manually for the purpose of a quick test.
[NEW] Device YY:YY:YY:YY:YY:YY <your smartphone>
[bluetooth]# trust YY:YY:YY:YY:YY:YY
Changing YY:YY:YY:YY:YY:YY trust succeeded
[bluetooth]# quit
Now you should be able to connect. And play Music !!!
3) Starting pulseaudio on boot
Your system won't be seen as an A2DP capable device until pulseaudio is launched. Let's start pulseaudio on boot.
[email protected]:~ $ systemctl --user enable pulseaudio
Created symlink /home/pi/.config/systemd/user/default.target.wants/pulseaudio.service → /usr/lib/systemd/user/pulseaudio.service.
Created symlink /home/pi/.config/systemd/user/sockets.target.wants/pulseaudio.socket → /usr/lib/systemd/user/pulseaudio.socket.
[email protected]:~ $ sudo raspi-config
And activate autologin for user "pi"
┌─────────┤ Raspberry Pi Software Configuration Tool (raspi-config) ├──────────┐
│ 1 Change User Password Change password for the current u │
│ 2 Network Options Configure network settings │
│ 3 Boot Options Configure options for start-up │
│ 4 Localisation Options Set up language and regional sett │
│ 5 Interfacing Options Configure connections to peripher │
│ 6 Overclock Configure overclocking for your P │
│ 7 Advanced Options Configure advanced settings │
│ 8 Update Update this tool to the latest ve │
│ 9 About raspi-config Information about this configurat │
│ <Select> <Finish> │
Select 3 Boot Options
│ B1 Desktop / CLI Choose whether to boot into a des │
│ B2 Wait for Network at Boot Choose whether to wait for networ │
│ B3 Splash Screen Choose graphical splash screen or │
│ <Select> <Back> │
Select B1 Desktop / CLI
│ B1 Console Text console, requiring user to login │
│ B2 Console Autologin Text console, automatically logged in as 'pi' user │
│ B3 Desktop Desktop GUI, requiring user to login │
│ B4 Desktop Autologin Desktop GUI, automatically logged in as 'pi' user │
│ <Ok> <Cancel> │
And choose B2 Console Autologin
Close raspi-config and reboot
At this stage, on your mobile, you can pair your Pi as a bluetooth audio speaker BUT you cannot connect if your mobile hasn't been trusted first.
4) Auto pairing / trusting / no PIN
Let's configure our Pi for bluetooth autopairing / trusting.
[email protected]:~ $ sudo apt-get install bluez-tools
The bluez-tools package comes with the bt-agent, bt-device, bt-adapter and bt-network commands, which are quite handy. I would recommend to have a look at their respective man pages.
[email protected]:~ $ sudo nano /etc/systemd/system/bt-agent.service
[Unit]
Description=Bluetooth Auth Agent
After=bluetooth.service
PartOf=bluetooth.service
[Service]
Type=simple
ExecStart=/usr/bin/bt-agent -c NoInputNoOutput
[Install]
WantedBy=bluetooth.target
[email protected]:~ $ sudo systemctl enable bt-agent
Created symlink /etc/systemd/system/bluetooth.target.wants/bt-agent.service → /etc/systemd/system/bt-agent.service.
[email protected]:~ $ sudo systemctl start bt-agent
[email protected]:~ $ sudo systemctl status bt-agent
● bt-agent.service - Bluetooth Auth Agent
Loaded: loaded (/etc/systemd/system/bt-agent.service; enabled; vendor preset:
Active: active (running) since Sat 2019-02-23 11:36:23 CET; 5s ago
Main PID: 503 (bt-agent)
CGroup: /system.slice/bt-agent.service
└─503 /usr/bin/bt-agent -c NoInputNoOutput
févr. 23 11:36:24 raspberrypi systemd[1]: Started Bluetooth Auth Agent.
févr. 23 11:36:24 raspberrypi bt-agent[503]: Agent registered
févr. 23 11:36:24 raspberrypi bt-agent[503]: Default agent requested
And now we're done ! Our Pi is an headless bluetooth speaker any mobile can connect, pair and play music with.
5) Not secure enough ? Let's add a (fixed) PIN
The bt-agent command allows you to add a PIN configuration file. Note that SSP must be deactivated.
[email protected]:~ $ sudo nano /etc/bluetooth/pin.conf
* 123456
[email protected]:~ $ sudo chmod 600 /etc/bluetooth/pin.conf
[Unit]
[Service]
Type=simple
ExecStart=/usr/bin/bt-agent -c NoInputNoOutput -p /etc/bluetooth/pin.conf
ExecStartPost=/bin/sleep 1
ExecStartPost=/bin/hciconfig hci0 sspmode 0
[Install]
[email protected]:~ $ sudo systemctl daemon-reload
[email protected]:~ $ sudo systemctl restart bt-agent
Loaded: loaded (/etc/systemd/system/bt-agent.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2019-02-24 09:34:42 UTC; 1min 26s ago
Process: 604 ExecStartPost=/bin/hciconfig hci0 sspmode 0 (code=exited, status=0/SUCCESS)
Process: 590 ExecStartPost=/bin/sleep 1 (code=exited, status=0/SUCCESS)
Main PID: 589 (bt-agent)
└─589 /usr/bin/bt-agent -c NoInputNoOutput -p /etc/bluetooth/pin.conf
févr. 24 09:34:41 raspberrypi systemd[1]: Starting Bluetooth Auth Agent...
févr. 24 09:34:41 raspberrypi bt-agent[589]: Agent registered
févr. 24 09:34:41 raspberrypi bt-agent[589]: Default agent requested
févr. 24 09:34:42 raspberrypi systemd[1]: Started Bluetooth Auth Agent.
Done.
6) Using an external USB dongle
As the onboard bluetooth module is not so good, especially when used in conjunction with the Wi-Fi onboard module, one may want to use an external dongle instead. I would definitely recommend it.
In that case, we need to disable the onboard bluetooth module
[email protected]:~ $ sudo nano /etc/modprobe.d/blacklist-bluetooth.conf
blacklist btbcm
blacklist hci_uart
[email protected]:~ $ sudo reboot
As simple as that.
7) Choppy sound, slitches, skips or crackling ?
This may be due to some troubles with pulseaudio resampling. Please have a look to
https://wiki.archlinux.org/index.php/Pu ... io_quality
That's all for today
