Alex.
Unusual RPi 3B
Thu Mar 07, 2019 6:29 pm
Hi all,
today I received the RPis 3B that I bought from my local reseller, but I scratched my head when, opening one, I found this
Yes, it looks like a 3B with 3B+'s SoC (prints on IHS say BCM2837B0).
Turns out it's just a BCM2837 packaged as a BCM2837B0. That's weird! :D
Has anyone else found one of these? What could be the most plausible explaination for this mislabeling?
W. H. Heydt
Re: Unusual RPi 3B
Thu Mar 07, 2019 8:21 pm
The BCM2837B0 is what was developed for the Pi3B+. It's also used on the Pi3A+, and CM3+ modules. I don't find it surprising that it would show up on the Pi3B, as that would be a means to reduce the number of different inventory items needed.
I'll have to keep my eyes peeled...perhaps it will show up on the Pi2Bv1.2, as well.
Or perhaps someone from the RPT would care to comment now that the cat appears to be out of the bag. Are *all* BCM2837 based Pis going to switch to the B0 stepping, allowing the A0 stepping to be discontinued?
Alex.
Re: Unusual RPi 3B
Thu Mar 07, 2019 8:31 pm
No, it's not a B0, it's the classic BCM2837 but packaged/labeled as as if it were.
I don't think that they're planning to change older models...
W. H. Heydt
Re: Unusual RPi 3B
Thu Mar 07, 2019 9:50 pm
What makes you think it's not a B0 stepping? They've never used that packaging for the A0 stepping. Since the silicon was both inverted and mirrored, the "pins" (balls, really, as it's a BGA system) are in the same relative position on both steppings, so they are truly "plug compatible". If the label says "B0", then one must presume it's a B0 stepping chip.
Now it may be the firmware, detecting that it's a Pi3B rather than a Pi3B+ might well default it to 1.2GHz, rather than 1.4GHz. And it might also be that the PCB hasn't changed, so the additional heat sink capability of the PCB isn't there, but none of that prevents it from being exactly what it's labeled as.
As for plans... I would point out that there was no announcement made when the Pi2B went from v1.1 with a BCM2836 to a v1.2 with a BCM2837. This is actually a much smaller change than that and could easily be done "under the radar".
And...just for curiosity...where did you buy it?
andrum99
Re: Unusual RPi 3B
Thu Mar 07, 2019 10:43 pm
The only difference in the B0 variant is the packaging, and the fact it says B0 on it. So if it says B0 then it *is* a B0.
W. H. Heydt
Re: Unusual RPi 3B
Thu Mar 07, 2019 10:52 pm
The B0 was turned over and mirrored.
jahboater
Re: Unusual RPi 3B
Thu Mar 07, 2019 11:11 pm
Larger power supply paths to the CPU cores (to improve stability under heavy load).
Re: Unusual RPi 3B
Thu Mar 07, 2019 11:21 pm
It's defo. a B0. Economies of scale and all that.
I'll post tomorow on any specifics. If I remember to ask.
Alex.
Re: Unusual RPi 3B
Thu Mar 07, 2019 11:27 pm
Uhm, ok.
But if it's a B0 how can it boot older raspbian images that don't boot on 3B+ (I tested it) ?
W. H. Heydt
Re: Unusual RPi 3B
Thu Mar 07, 2019 11:40 pm
If you remember, how about checking on the Pi2Bv1.2 as well.
drgeoff
Re: Unusual RPi 3B
Thu Mar 07, 2019 11:55 pm
There is more to the differences between a 3B and a 3B+ than the SoC and AIUI apart from the booting code in ROM and some of the OTP bits the original 2837 and the B0 version are electrically identical.
W. H. Heydt
Re: Unusual RPi 3B
Fri Mar 08, 2019 12:07 am
That brings up an interesting point... Will the Pi3B now come factory-ready to boot from a USB MSD?
Re: Unusual RPi 3B
Fri Mar 08, 2019 12:23 am
The 3B+ & 3A+ are both USB boot ready. There's no reason to assume that can't happen for 3B.
This is a doctor free zone.
drgeoff
Re: Unusual RPi 3B
Fri Mar 08, 2019 12:29 am
That is not what W.H. Heydt asked.
Quite possibly a 3B using the 2837B0 can be supplied in USB boot ready form. But would whoever has the say, choose to do that?
W. H. Heydt
Re: Unusual RPi 3B
Fri Mar 08, 2019 12:41 am
And, indeed, back when USB boot was in beta, there was talk about having the USB boot bit set in the factory...eventually. Since--at leat prior to this change--that hasn't happened (so far as anyone knows), it is reasonable, I think, to ask if it will with this change.
LTolledo
Re: Unusual RPi 3B
Fri Mar 08, 2019 1:22 am
Hi all,
Has anyone else found one of these? What could be the most plausible explanation for this mislabeling?
I like this! Hope my fave supplier have this stock soon! Me want one!
Some people be like:
Alex.
Re: Unusual RPi 3B
Fri Mar 08, 2019 8:37 am
Mine isn't USB boot ready
HawaiianPi
Re: Unusual RPi 3B
Fri Mar 08, 2019 9:40 am
Uhm, ok.
The 3B+ has different USB-Ethernet hub and WiFi chips. I assume the SoC is code compatible and it's the other chips that are the problem for older operating systems.
Burngate
Re: Unusual RPi 3B
Fri Mar 08, 2019 10:29 am
& power
& possibly under-voltage detection
6by9
Re: Unusual RPi 3B
Fri Mar 08, 2019 10:36 am
Yes the 3B is going to be shipping as standard with BCM2837B0.
The revision code hasn't changed as there are no functional differences that the kernel or firmware need to know about.
AIUI no other changes have been made to the board, so you don't get the extra thermal mass of the 3B+, nor changed PMIC, or anything else.
Re: Unusual RPi 3B
Fri Mar 08, 2019 12:49 pm
The only thing that concerns me here is the manufacturers of third party cases that have thermal pathways direct to the SoC. Some of them have different shims for 3B and 3B+, now they will need to tell people that the newer 3B will need to use the same shim as the 3B+. Some current 3B cases may not be compatible.
W. H. Heydt
Re: Unusual RPi 3B
Fri Mar 08, 2019 2:48 pm
Thanks for getting back with that bit of information.
