tinker2much
warning in recent wpa_supplicant update
Wed Mar 06, 2019 12:55 am
I just upgraded a bunch of my pi's and got this warning (pardon any typos - I'm retyping this from a screenshot):
"wpasupplicant (2:2.6-19) unstable; urgency=medium
With this release, wpasupplicant no longer responds to the system
default minimum TLS version, defaulting to TLSv1.0, not TLSv1.2. If
you're sure you will never connect to EAP networks requiring anything less
than 1.2, add this to your wpasupplicant configuration:
tls_disable_tlsv1_0=1
xls_disable_tlsv1_1=1
wpasupplicant also defaults to a security level 1, instead of the system
default 2. Should you need to change that, change this setting in your
[email protected]=2
Unlike wpasupplicant, hosted still respects system defaults.
-- Andrej Shadura <[email protected]> Sat, 15 Dec 2018 "
>>> DO I need to worry about this?
As a test, I added the following lines to /etc/wpa_supplicant/wpa_supplicant.conf, before the network= block.
tls_disable_tlsv1_1=1
[email protected]=2
And found that wireless wouldn't connect, removed them, and I could connect again.
Assuming that was the correct place and way to change those settings.
>>> Comments?
NOTE my current version is now:
sudo apt show wpasupplicant
Package: wpasupplicant
Version: 2:2.6-21~bpo9~rpt1
bls
Contact: Twitter
Re: warning in recent wpa_supplicant update
Wed Mar 06, 2019 3:27 am
Interesting...I installed it as well, with the same message. However, the tls_disable_... generate warnings from wpa_supplicant, which is why it didn't connect for you.
The good news is that this updated version appears to correct the problem I was having in https://www.raspberrypi.org/forums/view ... 6&t=234058.
Brolaf
Mon May 13, 2019 8:09 am
Updated raspbian yesterday (12.05), got same warning message. In my case after rpi reboot wifi can't connect anymore.
Any suggestions?
(Hi all btw, I'm new forum user).
Mon May 13, 2019 3:07 pm
Ignore it. It's entirely irrelevant. Ignoring it will not break your WiFi access.
This is a doctor free zone.
Brolaf
Mon May 20, 2019 11:12 am
Mine broke.
Mon May 20, 2019 12:25 pm
Mine broke.
Then fix your router/access point.
