nernan
disable gpu
Tue Mar 05, 2019 8:54 pm
i have a rpi3b+ im gonna be frank i have a usb monitor and i would like to disable onboard gpu so it can run, i checked it had its own separate gpu inside, its crazy! anyway thats all i need it disabled plz help
HawaiianPi
Re: disable gpu
Tue Mar 05, 2019 9:00 pm
The Pi SoC boots from the GPU. It's basically a GPU with an ARM processor tacked on. So I doubt it's possible to disable the GPU. And the Pi is USB 2.0 only, with all USB ports and Ethernet shared by a single USB 2.0 interface on the SoC, so I wouldn't expect much performance from a USB monitor.
W. H. Heydt
Re: disable gpu
Tue Mar 05, 2019 11:17 pm
In addition...GPU (VC4) blocks not being used get powered down automatically, so if you're not using them, they aren't drawing power anyway.
hippy
Re: disable gpu
Tue Mar 05, 2019 11:23 pm
A USB monitor, presumably DisplayLink, can run while the Pi's GPU is also running, so it might be best to actually describe what problem you are having or what issue you want to solve.
If it's that the desktop is appearing on the Pi's GPU monitor as well as the USB monitor; that can be adjusted using X11 configuration settings.
Or do you mean disable the GPU in the USB monitor ?
thagrol
Re: disable gpu
Tue Mar 05, 2019 11:42 pm
Doesn't display link us the primary GPU for the heavy lifting and only send the bits that have changed over USB? (https://en.wikipedia.org/wiki/DisplayLink#Technology)
In which case, disabling the GPU would stop the displaylink screen from working too.
Arguing with strangers on the internet since 1993.
Gavinmc42
Re: disable gpu
Tue Mar 05, 2019 11:50 pm
OP's 1st post?
"Needs" to turn off GPU?
Frankly crazy?
But hey, noobies are allowed a few dumb questions ;)
HDMI is not Displaylink, the Pi's don't do Displaylink.
Pi's are USB2.0 only, will it do Displaylink?
How fast would it go?
Open source DL Linux driver, does it work on Pi's?
Why not have HDMI and USB DL display, dual screen Pi's :D
I'm dancing on Rainbows.
thagrol
Re: disable gpu
Wed Mar 06, 2019 12:17 am
Nobody said it was and nothing I can think of does displaylink natively
Yes, displaylink works over USB2. Given the first devices went on sale in 2006 (source: https://en.wikipedia.org/wiki/DisplayLi ... ny_history) it pre-dates USB3
Not as fast as I'd like.
Someone posted a guide on the forum recently so I'd say yes. Don't know which driver they were using though.
hippy
Re: disable gpu
Wed Mar 06, 2019 1:10 am
Yes - https://www.raspberrypi.org/forums/view ... 0#p1437502
No idea. It's fast enough for me.
No idea. I just use whatever driver support is included with the Raspbain Stretch kernel.
Indeed; why not ? It's what I'm doing as well as others.
Probably this -
https://www.raspberrypi.org/forums/view ... 3&t=234586
http://multi-seat.com/raspbian-dual-monitors
Gavinmc42
Re: disable gpu
Wed Mar 06, 2019 5:32 am
Cool, next dumb question.
Is there client software for Raspbian(or any other OS) that turns a Zero +HDMI/DVI/DSI/DPI/LCD screen into a USB Displaylink client display?
5 screens on a Pi3B+ if using wireless keyboard mouse :D
Wonder if there is Free Pascal source for client?
hippy
Re: disable gpu
Wed Mar 06, 2019 11:39 am
Funnily enough I asked the same question a year ago -
https://www.raspberrypi.org/forums/view ... p?t=202518
As I noted: "Receiving is even easier than sending; just get a packet, decode it, put it to the right place in the frame buffer". Of course there's more to it than that but I can't see that it couldn't be done.
And some people seem to have done it, at least as proof of concept, including -
https://www.spinics.net/lists/linux-usb/msg133383.html
"We have ffs daemon and ConfigFS config to setup and act like a display link with 640x480 monitor. So on a host side we see another monitor and on the device side we have an window in which we can see image from host".
But I couldn't find any g_displaylink gadget or anything else showing how to do it, but I didn't search very far.
I don't know, but as there seems to be nothing for anything I'd be surprised if it only existed in a Free Pascal form.
If there is and it works with Raspbian, or particularly Ultibo, it would be extremely useful to have, an easy and cheap way to turn any HDMI or composite TV, any Pi supported LCD, into a USB DisplayLink monitor.
