Some context may help
I'm trying to use a TEG, Thermo Electric Generator, to cool my Pi.
The idea is the TEG consumes the excess heat put off by the SOC and converts it into electrical energy, thereby removing heat from the SOC and "cooling" it by spreading the heat into the surrounding atmosphere.
The energy
The TEG specs are hereń
Specifications
Model:SP1848-27145
Color :white
Lead Length: about 30CM
Size: 40MM * 40MM* 3.4MM
20 degree temperature difference: open-circuit voltage 0.97V, generated current: 225MA
40 degree temperature difference: open circuit voltage 1.8V, generated current: 368MA
60 degree temperature difference: open circuit voltage 2.4V, generated current: 469MA
80 degree temperature difference: the open circuit voltage 3.6V, generated current: 558MA
100 degree temperature difference: open circuit voltage 4.8V, generated current: 669MA
I have no idea how to interpret open circuit voltage, but I know that when I set it up and run CPU BURN on my Pi, it only generates 0.16v and so my fan never turns on, the thermal delta is not maintained and I end up with a thermally throttling Pi after ten minutes. (after which, a very disappointed me takes the contraption apart and near breaks his monitor after instinctively throwing the scaldingly hot chunk of aluminium he just picked up
The fan only requires about 0.15A @5v and I have tested it to work as low as 1.5v
I figured if I could step the voltage up enough to get the fan to turn, it might work, but I am not able to get the required voltage for the fan to work.
Anybody got any ideas or should I abandon this silly idea?
I can always use it as a TEC.
