Hi all,
A while ago I started using the CM3 and used https://www.raspberrypi.org/documentati ... display.md to build a custom dt-blob.bin to enable the display. I'm not revisiting this as I want to use Noobs with the device and found I could only get the display to work with Noobs when my dt-blob.bin was on the recovery partition.
Am I correct in that you can't enable the official display with the CM3 just by providing an overlay via config.txt, you have to always use a dt-blob.bin?
