Cr4z33
A command is executed whenever I open the Terminal window
Thu Feb 28, 2019 3:44 pm
Last week I was trying different methods to run a command to turn the TV on at Pi start, but now that I am done with a working solution I noticed a problem.
Whenever I open a Terminal window the same command I am currently using with a script is executed automatically and I have no clue on how to get rid of it. :evil:
Where shall I start looking?
scruss
Re: A command is executed whenever I open the Terminal window
Thu Feb 28, 2019 3:59 pm
You probably edited your .bashrc, .profile or .bash_profile files. If the command you don't want to run is command, try
grep command ~/.*
and you'll get a list of matches with the filename first in the line.
Cr4z33
Thu Feb 28, 2019 4:09 pm
Thanks that did the trick! :mrgreen:
As soon as I looked into /home/pi/.bashrc I found the command and removed it.
