evgeny_co
Low FPS, Rasberrry 3b+, CSI camera V2.1
Fri Feb 22, 2019 6:00 pm
Hi everyone!
For me CSI is fast, but when I do frame capture from the CSI camera V2.1 , I get low FPS (approx 7) at 960 х 720 resolution:(
I use rasberry pi 3b+.
Maybe I made a mistake in the code, but tried different options.
rom __future__ import print_function
from picamera.array import PiRGBArray
from picamera import PiCamera
import imutils
import time
import cv2
import datetime
# initialize the camera and stream
camera = PiCamera()
camera.resolution = (960, 720)
camera.framerate = 32
rawCapture = PiRGBArray(camera, size=(960, 720))
stream = camera.capture_continuous(rawCapture, format="bgr",
use_video_port=True)
start_time = datetime.datetime.now()
mean_fps1 = []
# loop over some frames
for (i, f) in enumerate(stream):
	frame = f.array
	cv2.imshow("Frame", frame)
	key = cv2.waitKey(1) & 0xFF
	rawCapture.truncate(0)
	mean_fps1.append(i)
	# check to see if the desired number of frames have been reached
	if i == 100:
		break
t2 = (datetime.datetime.now() - start_time).total_seconds()
# stop the timer and display FPS information
print("[INFO] approx. FPS: {:.2f}".format(len(mean_fps1)/t2))
cv2.destroyAllWindows()
stream.close()
rawCapture.close()
camera.close()
I get ~7 fps.
Maybe it's normal, i don't know.
I really appreciate any help you can provide.
paddyg
Re: Low FPS, Rasberrry 3b+, CSI camera V2.1
Mon Feb 25, 2019 10:28 pm
Probably alternative simpler methods but I did something a while ago (based on the picam docs I think) that used a io.BytesIO and a thread pool to up the frame rate. https://github.com/pi3d/pi3d_demos/blob ... re_fast.py I wanted to get the frames as numpy arrays so there's complication in there that you don't need.
PS somewhere here https://picamera.readthedocs.io/en/rele ... processing
PPS I don't know how fast imshow will run on the RPi
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
Return to “Python”
