I am trying to flash the Debian OS on the Partition using the dd command.
dd if=os.img bs=10M of=/dev/mmcblk0p1Code: Select all
3565158400 bytes (3.6 GB, 3.3 GiB) copied, 297 s, 12.0 MB/s
106+1 records in
106+1 records out
3565158400 bytes (3.6 GB, 3.3 GiB) copied, 296.587 s, 12.0 MB/sI am getting the following error:
mount: wrong fs type, bad option, bad superblock on /dev/mmcblk0p1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so.Code: Select all
[ 856.292964] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 856.292983] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
[ 856.305466] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 856.305483] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 2th superblock
[ 856.315244] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 856.315256] F2FS-fs (mmcblk0p1): Can't find valid F2FS filesystem in 1th superblock
[ 856.324437] F2FS-fs (mmcblk0p1): Magic Mismatch, valid(0xf2f52010) - read(0x0)Units: sectors of 1 * 512 = 512 bytesBut if I try the dd command on mmcblk0 disk it is working perfectly. I am able to mount and boot.
According to my understanding, Linux OS is designed to be installed on a disk, not on a partition and dd is to be used for the flashing on the disk.
I want to write a Debian image on a Partition mmcblk0p1 using a command line tool. How can I achieve this?
I tried dd, pv, cat, cp, ddsd, Dcfldd But ended up with the same result.
