because my old post was very unstructured at some point and the initial problem was solved I wanted to create this new post to address my new current problem.
I'm a student and have gathered some experience with multiple programming languages in the past few years but SPI and everything directly related is quite new to me.
My goal with my current project is it to use a raspberry pi to communicate with 2 BMS chips via SPI using Python (spidev). In the end the BMS should give me the current of the Cells (each has 12 Lithium Ion Cells) and I want to use the BMS's balancing function to ensure a equal charge level of all cells.
Problem: When both devices are connected the output for the second device is just a copy of the first one and I have no idea why
When only one of the devices itself are connected to output is completely correct
Update: The problem now also occurred when just one device (device 0) is connected. (repeatedly=
Raspberry: Raspberry Pi 3 Model B
OS: Raspbian
BMS: ISL78600
Wiring is similar to this picture:
SPI master: Raspberry Pi
Slave 0 and 1: BMS chip
Actual wiring:
spidev connection settings:
# SPI connection
spi0 = spidev.SpiDev()
spi0.open(0, 0)
spi0.bits_per_word = 8
spi0.max_speed_hz = 100000
spi0.mode = 0
spi0.lsbfirst = False
spi1 = spidev.SpiDev()
spi1.open(0, 1)
spi1.bits_per_word = 8
spi1.max_speed_hz = 100000
spi1.mode = 0
spi1.lsbfirst = False
General simplified structure of communication:
while device < len(devices)
spi.writebytes(CELL_REGISTER)
response = spi.readbytes(2)
CELL_VOLTAGE = single_cell_voltage_calc(response[0], response[1])
print(CELL_VOLTAGE)
Only device 0 is connected (behavior 1):
SPI INFO: SPI read cell and battery voltage from dev0 and dev1
Dev0-CELL01: 4.075 V Dev1-CELL01: ERR V
Dev0-CELL02: 4.073 V Dev1-CELL02: ERR V
Dev0-CELL03: 4.073 V Dev1-CELL03: ERR V
Dev0-CELL04: 4.075 V Dev1-CELL04: ERR V
Dev0-CELL05: 4.074 V Dev1-CELL05: ERR V
Dev0-CELL06: 4.075 V Dev1-CELL06: ERR V
Dev0-CELL07: 4.075 V Dev1-CELL07: ERR V
Dev0-CELL08: 4.075 V Dev1-CELL08: ERR V
Dev0-CELL09: 4.073 V Dev1-CELL09: ERR V
Dev0-CELL10: 4.071 V Dev1-CELL10: ERR V
Dev0-CELL11: 4.074 V Dev1-CELL11: ERR V
Dev0-CELL12: 4.074 V Dev1-CELL12: ERR V
Dev0-BATTERY: 48.843 V Dev1-BATTERY: ERR V
Only device 1 is connected (behavior 2):
Dev0-CELL01: ERR V Dev1-CELL01: 4.085 V
Dev0-CELL02: ERR V Dev1-CELL02: 4.083 V
Dev0-CELL03: ERR V Dev1-CELL03: 4.084 V
Dev0-CELL04: ERR V Dev1-CELL04: 4.085 V
Dev0-CELL05: ERR V Dev1-CELL05: 4.086 V
Dev0-CELL06: ERR V Dev1-CELL06: 4.086 V
Dev0-CELL07: ERR V Dev1-CELL07: 4.085 V
Dev0-CELL08: ERR V Dev1-CELL08: 4.085 V
Dev0-CELL09: ERR V Dev1-CELL09: 4.085 V
Dev0-CELL10: ERR V Dev1-CELL10: 4.085 V
Dev0-CELL11: ERR V Dev1-CELL11: 4.087 V
Dev0-CELL12: ERR V Dev1-CELL12: 4.086 V
Dev0-BATTERY: ERR V Dev1-BATTERY: 48.975 V
How it should look like when both are connected (behavior x):
Dev0-CELL01: 4.075 V Dev1-CELL01: 4.085 V
Dev0-CELL02: 4.073 V Dev1-CELL02: 4.083 V
Dev0-CELL03: 4.073 V Dev1-CELL03: 4.084 V
Dev0-CELL04: 4.075 V Dev1-CELL04: 4.085 V
Dev0-CELL05: 4.074 V Dev1-CELL05: 4.086 V
Dev0-CELL06: 4.075 V Dev1-CELL06: 4.086 V
Dev0-CELL07: 4.075 V Dev1-CELL07: 4.085 V
Dev0-CELL08: 4.075 V Dev1-CELL08: 4.085 V
Dev0-CELL09: 4.073 V Dev1-CELL09: 4.085 V
Dev0-CELL10: 4.071 V Dev1-CELL10: 4.085 V
Dev0-CELL11: 4.074 V Dev1-CELL11: 4.087 V
Dev0-CELL12: 4.074 V Dev1-CELL12: 4.086 V
Dev0-BATTERY: 48.843 V Dev1-BATTERY: 48.975 V
How it is when both are connected (behavior 3):
Dev0-CELL01: 4.075 V Dev1-CELL01: 4.075 V
Dev0-CELL02: 4.073 V Dev1-CELL02: 4.073 V
Dev0-CELL03: 4.073 V Dev1-CELL03: 4.073 V
Dev0-CELL04: 4.075 V Dev1-CELL04: 4.075 V
Dev0-CELL05: 4.074 V Dev1-CELL05: 4.074 V
Dev0-CELL06: 4.075 V Dev1-CELL06: 4.075 V
Dev0-CELL07: 4.075 V Dev1-CELL07: 4.075 V
Dev0-CELL08: 4.075 V Dev1-CELL08: 4.075 V
Dev0-CELL09: 4.073 V Dev1-CELL09: 4.073 V
Dev0-CELL10: 4.071 V Dev1-CELL10: 4.071 V
Dev0-CELL11: 4.074 V Dev1-CELL11: 4.074 V
Dev0-CELL12: 4.074 V Dev1-CELL12: 4.074 V
Dev0-BATTERY: 48.843 V Dev1-BATTERY: 48.843 V
Behavior 1 and 2 are correct and as expected. Behavior 3 is wrong and the expected output would be behavior x.
Did anybody already experience a issue like this ? That devices are interfering each other somehow ?
Thank you for any held or advice in advance, if any further information is needed please ask!
