Slighty
RetroPi - updated, now only Command Prompt.
Tue Feb 19, 2019 11:49 am
Ladies & Gents
I had RetroPi working brilliantly on the RPi Model 2b+
Not used it in a while and knew there was a RetroPi upgrade
Made the (clearly now foolish) decision to upgrade, it ran scripts and all sorts NOW it sits at the Command Prompt,
If i type 'EmulationStation' - as previously to return from terminal back to Retro Pi screen goes black and return to Terminal / Command prompt.
When I boot up i get the RetroPi splash Image however i never see the Emulation Station splash page..
I am assuming the hardware cant cope with the Software - I can of course re-image etc but any quicker ideas are welcomed.
Regards
B.Goode
Re: RetroPi - updated, now only Command Prompt.
Tue Feb 19, 2019 12:17 pm
Since you query hardware compatibly, can you confirm the model of your RPi? The Raspberry Pi Foundation reference documents don't have a Model 2B+.
How did you originally install RetroPie? As a turnkey image, or as an add-on to a base Raspbian system?
What did you actually do to implement the upgrade?
Slighty
Tue Feb 19, 2019 1:15 pm
ops My bad....
Must have my numbers/models mixed up
Model: Rasp Pi model 2b
Image : Turnkey - I downloaded it originally to SD extracted it an ran from source, it was never an Icon in Raspbian as i believe it can be now.
Method of Updating: Ran the Sudo Nano - Update all command as advised by some website somewhere ..
Thanks in advance...
B.Goode
Tue Feb 19, 2019 1:35 pm
nano is simply a text editor. That is unlikely on its own to invoke a failed update to your system.
It would be invaluable to know exactly what "command as advised by some website somewhere ."
Alternatively, make a backup of any personal data on the system and make a fresh start..
Return to “Gaming”
