sapnho
Need help modifying a Gmail message retrieval script
Thu Feb 14, 2019 5:55 pm
I am trying to figure out a Python script to download attachments from a Gmail account if a certain subject line matches. I found the attached from 2015 which works perfectly but there is no checking of the subject line included. Can somebody tell me how to add the subject line check (e.g. if subject line does not include "grandmother" then ignore)
#!/usr/bin/env python3
# read emails and detach attachment in attachments directory
import email
import getpass, imaplib
import os
import sys
import time
detach_dir = '.'
if 'attachments' not in os.listdir(detach_dir):
    os.mkdir('attachments')
userName = 'testxxxx'
passwd = 'password'
try:
    imapSession = imaplib.IMAP4_SSL('imap.gmail.com',993)
    typ, accountDetails = imapSession.login(userName, passwd)
    if typ != 'OK':
        print ('Not able to sign in!')
        raise
    imapSession.select('Inbox')
    typ, data = imapSession.search(None, 'ALL')
    if typ != 'OK':
        print ('Error searching Inbox.')
        raise
    # Iterating over all emails
    for msgId in data[0].split():
        typ, messageParts = imapSession.fetch(msgId, '(RFC822)')
        if typ != 'OK':
            print ('Error fetching mail.')
            raise
        emailBody = messageParts[0][1] #print(type(emailBody))
        mail = email.message_from_bytes(emailBody) #mail = email.message_from_string(emailBody)
        for part in mail.walk():
            #print (part)
            if part.get_content_maintype() == 'multipart':
                # print part.as_string()
                continue
            if part.get('Content-Disposition') is None:
                continue
            fileName = part.get_filename()
            if bool(fileName): #add second condition of subjet line which must match
                filePath = os.path.join(detach_dir, 'attachments', fileName)
                if not os.path.isfile(filePath) : #check duplication
                    print (fileName)
                    print (filePath)
                    fp = open(filePath, 'wb')
                    fp.write(part.get_payload(decode=True))
                    fp.close()
    imapSession.close()
    imapSession.logout()
except :
    print ('Something went wrong')
    time.sleep(3)
www.TheDigitalPictureFrame.com
Build a really great digital picture frame with the Raspberry Pi.
With lots of great tips from this forum.
MrYsLab
Re: Need help modifying a Gmail message retrieval script
Thu Feb 14, 2019 8:48 pm
Take a look at this link in the python docs. Perhaps it is what you are looking for. https://docs.python.org/3.7/library/ima ... AP4.search
sapnho
Fri Feb 15, 2019 7:51 am
Thanks, yes I know this one, but I am not proficient enough in Python to figure this out.
PhatFil
Fri Feb 15, 2019 8:57 am
IMAP4.search(charset, criterion[, ...])
Search mailbox for matching messages. charset may be None, in which case no CHARSET will be specified in the request to the server. The IMAP protocol requires that at least one criterion be specified; an exception will be raised when the server returns an error. charset must be None if the UTF8=ACCEPT capability was enabled using the enable() command.
Example:
# M is a connected IMAP4 instance...
typ, msgnums = M.search(None, 'FROM', '"LDJ"')
# or:
typ, msgnums = M.search(None, '(FROM "LDJ")')
so perhaps start trying replacing your script line
with something like
typ, data= imapSession.search(None, 'SUBJECT', '"THIS EMAIL HAS AN ATTACHMENT"')
maybe?
MrYsLab
Fri Feb 15, 2019 9:16 am
Another link to look at: https://pymotw.com/3/imaplib/#search-criteria. There is a sample of code searching for "from".
#  imaplib_search_from.py
import imaplib
import imaplib_connect
from imaplib_list_parse import parse_list_response
with imaplib_connect.open_connection() as c:
    typ, mbox_data = c.list()
    for line in mbox_data:
        flags, delimiter, mbox_name = parse_list_response(line)
        c.select('"{}"'.format(mbox_name), readonly=True)
        typ, msg_ids = c.search(
            None,
            '(FROM "Doug" SUBJECT "Example message 2")',
        print(mbox_name, typ, msg_ids)
Idahowalker
Fri Feb 15, 2019 12:22 pm
gmail accounts are free. I made an account just for my RPi. All the mail received by that account is just for the RPi. After making the account, send an email from that account to your main account and reply. Seems gmail accounts like a 2 way communication.
Without knowing why you are deleting my postings, I will not know how...
sapnho
Fri Feb 15, 2019 1:17 pm
with something like
You are amazing, thank you, it works great!
sapnho
Fri Feb 15, 2019 1:18 pm
Yeah, that's what I did as well. Did you experience any issues or why do you recommend the two-way communication?
Idahowalker
Fri Feb 15, 2019 1:37 pm
During testing, after about receiving 1000ish emails, and nothing sent, emails just stopped being received. I logged into the account sent an email and have had not issue since ( over a year).
sapnho
Fri Feb 15, 2019 1:45 pm
After solving the first big issue, I have two more remaining if I may be so bold. :oops:
- How can I limit the download of any attachments to only jpg files?
- How can I delete the emails after processing? Both those with or without a valid attachment.
I read on https://www.timpoulsen.com/2018/reading ... ython.html that deleting with Gmail is a bit more tricky. This is his code but again I would need help where and how to place it in my above script...
def delete_message(self, msg_id):
        if not msg_id:
            return
        if self.move_to_trash:
            # move to Trash folder
            self.imap.store(msg_id, '+X-GM-LABELS', '\\Trash')
            self.imap.expunge()
        else:
            self.imap.store(msg_id, '+FLAGS', '\\Deleted')
            self.imap.expunge()
sapnho
Makes sense, good tip, thanks!
PhatFil
Sat Feb 16, 2019 4:24 pm
may i suggest you dont delete the emails, instead once processed move them to a 'Processed' folder so they can be archived and then saved or deleted as appropriate.
a system with an automatic delete feature can create an unrecoverable error condition, while if you have an archive of all source data any errors can be corrected and backtracked.
sapnho
Sat Feb 16, 2019 4:30 pm
Yes, that's a good point. But how do I move them? :?
PhatFil
Sat Feb 16, 2019 11:58 pm
Your example code snippet is moving email to the trash folder, so just replave the trash reference with a reference to the folder you want to move to, and create the folder in advance ;)...
what have you tried? how did it go? it looks like your on the right track finding examples but are not trying to use them. you wont break anything putting in a badly formatted command, but any errors you raise will probably tell you what you have done wrong, and while error messages may appear oblique to start with the only way to get used to the language used and what is meant is by getting stuck in..
One hint
the code snippet your trying to import is pulled from an imap class definition so unless your intending to mirror that and define your own imap class look at replacing the self references with the imap object you are using (imapsession iirc) and i think you can probably just call the function pretty much as is?? I dont know as i haven't tested it though..
sapnho
Sun Feb 17, 2019 9:03 am
My problem is that I have no idea where to put that code snippet. This is how I understand it.
try:
	if typ != 'OK':
		raise
This just established the connection to Gmail.
	typ, data = imapSession.search(None, 'SUBJECT', '"#mypictures"')
	if typ != 'OK':
		raise
This checks if there are any emails with "#mypictures" in the subject line.
Let's assume, there are none but other emails (that I want to move to "Processed"), then I guess I would have to add
else:
	imap.store(msgId, '+X-GM-LABELS', '\\Processed')
So the section would look like:
		if typ != 'OK':
			raise
			#print (part)
				continue
				continue
					print (fileName)
					print (filePath)
					fp.close()
	else:
	imapSession.close()
But this does nothing to emails that do not have "#mypictures" in the subject line. No error message, just nothing happens.. :?
PhatFil
Sun Feb 17, 2019 9:10 pm
As a beginner with python myself there may be more python-esq methods employing try/catch.. But I would start with peppering the script with print or write statements to validate that the collected data conforms to your expectations.
Also confirm the contents of the inbox you are querying....
have you selected any messages that should be moved and have you got them when your trying to move them? if so
look at the move command more closely.
edit
when it comes to the move command insert print statements identifying the message uid you want to move and print out its subject line too then if it isnt moved.. well your program logic correctly?identified a message to move and you have confirmed its indexed correctly and accessible to your code at that point.....
sapnho
Mon Feb 18, 2019 6:09 pm
With a little help from a gifted Python programmer and everyone here in this thread, my solution is now working.
I have summarized it on my blog: https://www.thedigitalpictureframe.com/ ... via-email/
Thanks @PhatFil and @Idahowalker!
Return to “Python”
