njsss
wiringPi problems with CM3+
Tue Feb 12, 2019 10:23 pm
I tried a CM3+ and CM3+ lite, they both have problems with wiringPi.
gpio readall
gives error "unable to determine board type ... model 16".
I checked the wiringPi version it is up to date 2.46. My raspbian kernel is 4.14.79 #1159 the newest too. Need some help here.
Andyroo
Re: wiringPi problems with CM3+
Tue Feb 12, 2019 10:35 pm
Have a look at this topic for changes needed to support the 3A+ https://www.raspberrypi.org/forums/view ... ?p=1420267
You may be able to mod it for this board.
njsss
Tue Feb 12, 2019 11:14 pm
I see thanks! I think I'll just keep developing with my CM3 for now till his official update.
Greg Erskine
Wed Feb 13, 2019 12:21 am
I think you will be waiting a while. :)
Gordon hasn't updated wiringPi since 14 March 2018 for the RPi3B+. He hasn't updated for the RPi3A+.
I am not sure if Gordon is unwell or lost interest?
* Raspberry Pi is a trademark of the Raspberry Pi Foundation
Wed Feb 13, 2019 7:47 am
Greg Erskine
Wed Feb 13, 2019 8:41 am
Thanks.
So he has lost interest in maintaining his wiringPi web site. :(
Good to see he is OK! :mrgreen:
TimWJ
Wed Feb 13, 2019 6:33 pm
This is Odd.
I have been using WiringPi 2.46 on CM3 and CM3 Lite for about 6 months.
I am using an old kernel, I think that it is 4.9.22.
Out of the box it works fine, but only supports one SPI bus and there is a bug in the MCP3002 ADC code. I added support for the other 2 SPI buses and fixed the MCP3002 bug. I emailed the changes to Gordon but never heard anything back.
If it helps I can fire up the CM3 Lite system tomorrow.
Tim.
6by9
Wed Feb 13, 2019 6:46 pm
It's the cm3+ and 3a+ that have issues as wiring Pi doesn't have the right revision code lookup. All older Pi variants are supported.
Wed Feb 13, 2019 6:57 pm
Hacking it to make it work for unsupported boards isn't hard. Hacking it as a production ready *.deb that's part of Raspbian is something that only Gordon can do (because beyond that lies chaos).
PhilE
Wed Feb 13, 2019 6:59 pm
If all you need is the gpio readall functionality, "raspi-gpio get" works on all Pis.
njsss
Thu Feb 14, 2019 12:13 am
So I installed the "official" deb file, "gpio -v" gives correct information "Compute Module 3 Plus". Yet gpio readall still doesn't work. It seems other gpio functions are working (set/write pins), but do really like the IO printout.
I use its functions in my program, so hopefully, nothing breaks.
DRAgon715205
Fri Mar 01, 2019 4:45 am
hello
I have got the 2.48 version wiringpi
the same wiringpi program can work at CM3(GPIO I2C SPI all work well)
But work error at CM3+ (same gpio do not run and I2C SPI PWM do not work with the same Progame)
please tell me how can I solve this problem ??
Fri Mar 01, 2019 5:59 am
https://www.raspberrypi.org/forums/view ... 8&t=231942
You can patch the code yourself. It's not difficult.
DRAgon715205
Fri Mar 01, 2019 9:45 am
but which is A+ not CM3 +
and do not the same error , which is error model:14 , my is error model 16
as which method,
I need make which changes ? , to change A+ to CM3+ ?
Fri Mar 01, 2019 10:00 am
Look at my patch https://www.raspberrypi.org/forums/view ... 2#p1420568
You should be able to apply that and hack it for a model 16 device.
I don't have the time (even though I've got a 3B here with me on holiday).
Return to “Compute Module”
