tony359
wall mounting touch screen and Pi
Mon Feb 11, 2019 11:31 pm
Hi there,
I'd like to wall mount my Pi so it can control the heating.
Looking for wall mounting cases I did not found much and the obvious choice seems to be the official Pi case.
However, I am concerned as that case hosts the Pi at the bottom (or top if you want) and there is no bezel where the Pi sits. If I cut a hole in my wall, then I'd be able to see the edges of the hole if the case is not covering it - do I make sense?
Am I missing something here?
Tony
pcmanbob
Re: wall mounting touch screen and Pi
Tue Feb 12, 2019 3:07 pm
tony359
Tue Feb 12, 2019 6:38 pm
Thanks, I had already found two of them indeed. The instructable implies an US wall box if not mistaken which I am not sure I can source in the UK. The other two solutions are VERY expensive...
tony359
Thu Feb 21, 2019 8:12 pm
any other DYI solution I can try? or cheaper for what matters.
