theMusicMan
Syntax for running shell command in Python
Thu Feb 07, 2019 12:33 pm
Hi All
I would like to run the shell command;
vcgencmd measure_temp
... which runs perfectly in the terminal, within a Python script, assigning that to a variable for subsequent
cpu_temp = subprocess.check_output("vcgencmd measure_temp", shell=True)
I tried the above (obtained from elsewhere) but the result returned is not what I expected, which is;.
b"temp=52.6'C/n"
Could someone offer some advice please, many thanks.
pcmanbob
Re: Syntax for running shell command in Python
Thu Feb 07, 2019 1:48 pm
If you just want the temperature value you can do it like this
with open("/sys/class/thermal/thermal_zone0/temp", "r") as file:
    temp = float(file.read())
tempC = temp/1000
print (tempC)
but if you want the output as a string including the text then this code
tempC = temp/1000
tempC = str(tempC)
output = "temp=" + tempC + "'C"
print (output)
MrYsLab
Thu Feb 07, 2019 4:10 pm
If you wish to us Popen, this will work:
import subprocess
# execute the command using Popen
sb = subprocess.Popen(['vcgencmd', 'measure_temp'], stdout=subprocess.PIPE)
# get the command output
cmd_out = sb.communicate()
# convert from byte string to string
temp = cmd_out[0].decode()
print(temp)
And here is the output when I run this:
pi@RPi3BP:~ $ python3 pop.py
temp=44.0'C
Return to “Python”
