juanseb wrote: ↑Sat Feb 02, 2019 2:59 am
I don't know how to link the RFID with the user/password in the server
Well, if there's only one RFID per user, you can add a new coloumn to the users table in your database. Otherwise I'd suggest to use a new rfiduser table. If you have an SQL database, that would be:
SELECT users.* FROM rfiduser LEFT JOIN users ON rfiduser.userid=users.userid WHERE rfiduser.rfid='x';
Anyway, I think you should have two different authentication levels:
1. RPi should use SSL/TLS with client certificate validation to access the REST API (apache and libcurl can be configured easily to do so). You do not pass the user/password, only the RFID along with the REST request, and maybe a long API key that you can check from your Ruby code.
2. users using the server's web interface use the usual user/password authentication
The point is, you move the logic to the server side, where your Ruby code can get the user's record using only the RFID (because of the SSL/TLS, cert auth and API key, this should be secure enough even without a password). The other option would be to connect RFID to user/pass on the RPi side and play a web login with the REST API, but that poses several managability and security issues (how would you keep the user/pass database up-to-date on the RPi securely?).
Cheers,
bzt
