wjumaat
CRON not executing SH file
Fri Feb 01, 2019 8:07 am
Dear All,
My objective is to restart the PI daily at a fixed time.
I wrote a script using nano.
nano home/pi/reboot.sh
Then on crontab, I inserted the command
57 15  * * * chmod +x /home/pi/reboot.sh
Till now, I am still unable to execute the command automatically.
Your advise is much appreciated.
Peace be upon you,
Wandi bin Juma'at
pcmanbob
Re: CRON not executing SH file
Fri Feb 01, 2019 11:11 am
Hi.
Your cron line is incorrect all that will do is make the file reboot.sh executable.
to actually call the file you would have a cron line like this.
57 15  * * *  /home/pi/reboot.sh
and you should not call your file reboot.sh as reboot is a command this will just cause your pi to get confused, so you should change the file name to some thing else
examples myreboot.sh, nowreboot.sh
Fri Feb 01, 2019 12:15 pm
Nonsense. reboot.sh is not the same as reboot. Unlike certain other operating systems, Linux uses the whole file name, not just the part before the dot if it is followed by certain other characters. reboot.exe for example.
wjumaat
Wed Feb 27, 2019 1:53 am
Hi All,
Sorry for the late reply.
I managed to resolve the problem. Perhaps, I guess the issue was that i did not make the sh file executable with the chmod +x command.
Thank you.
Peace be upon you,
Wandi bin Juma'at
raspby66
Fri May 24, 2019 6:23 am
Hi All,
Thank you.
Would you mind terribly listing the *complete* commands in your script to have your PI reboot itself on a daily basis. I understand writing that script using nano. But what did you put in the chron file to accomplish the running of the script? Finally would you detail the chmod command for the script? Thanks very much!
Regards!
RaTTuS
Fri May 24, 2019 8:10 am
you don't really want to; but if you
sudo crontab -e
57 15 * * * /sbin/reboot
this will reboot your machine at 57 mins pas 15 every day
Covfefe
raspby66
Fri May 24, 2019 2:17 pm
sudo crontab -e
Please tell me if the 3 asterisks are supposed to represent something that I must complete or do I type out the whole line just like you have?
pcmanbob
Fri May 24, 2019 2:22 pm
sudo crontab -e
Yes the 3 asterisks are supposed to be there they indicate you want the job to run every day , every month and every weekday.
may be helpful is you are new to using cron.
https://www.raspberrypi.org/documentati ... ge/cron.md
https://crontab-generator.org/
dl324
Fri May 24, 2019 2:56 pm
man is your friend.
man 5 crontab
<snip>
       Commands  are  executed  by cron(8) when the minute, hour, and month of
       year fields match the current time, and when at least one  of  the  two
       day  fields  (day of month, or day of week) match the current time (see
       ``Note'' below).  cron(8) examines cron entries once every minute.  The
       time and date fields are:
              field          allowed values
              minute         0-59
              hour           0-23
              day of month   1-31
              month          1-12 (or names, see below)
              day of week    0-7 (0 or 7 is Sun, or use names)
       A field may be an asterisk (*), which always stands for ``first-last''.
The following are special options that are used instead of the first 5 fields
       Instead  of  the  first  five  fields, one of eight special strings may
       appear:
              string         meaning
              @reboot        Run once, at startup.
              @yearly        Run once a year, "0 0 1 1 *".
              @annually      (same as @yearly)
              @monthly       Run once a month, "0 0 1 * *".
              @weekly        Run once a week, "0 0 * * 0".
              @daily         Run once a day, "0 0 * * *".
              @midnight      (same as @daily)
              @hourly        Run once an hour, "0 * * * *".
       Please note that startup, as far as @reboot is concerned, is  the  time
       when  the cron(8) daemon startup.  In particular, it may be before some
       system daemons, or other facilities, were startup.  This is due to  the
       boot order sequence of the machine.
