virtualstudent
Installing Xen on Raspberry Pi
Sun Jan 27, 2019 11:22 pm
Hi all,
I wish to install Xen hypervisor on my Raspberry Pi 3 on which I'm running Raspbian OS at the moment. I didn't find any proper reference online regarding this. Can anyone help me out with the steps and also an information on whether I should consider running a different OS instead of Raspbian.
Thanks.
Re: Installing Xen on Raspberry Pi
Mon Jan 28, 2019 2:08 am
Hi all,
Thanks.
It does not appear to be supported ?
https://wiki.xenproject.org/wiki/Xen_AR ... Extensions
Asus ChromeBox 3 Celeron is my other computer.
virtualstudent
Mon Jan 28, 2019 4:56 pm
Xen support is present for ARM Cortex A53 which is present in Raspberry Pi 3 but what I'm looking for is if someone could successfully do it or faced some specific issues. I went browsing on the internet to find if anyone could run Xen either with Raspbian or Ubuntu on Pi but did not come across anything useful and complete in a sense. Any help will be appreciated. Thanks.
Mon Jan 28, 2019 5:16 pm
There is far more than just CPU compatibility, that is a very simplistic motion.
code_exec
Mon Jan 28, 2019 5:56 pm
Hi all,
Thanks.
I'm sure that you can enable Xen on the Pi by recompiling the kernel with Virtualisation and Xen guest support.
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
virtualstudent
Mon Jan 28, 2019 9:23 pm
Yeah, I'm already trying to compile 64 bit kernel (ARM-v8) on the Pi and give it a try then.
rajagopal
Sat Jul 20, 2019 2:45 am
Hello virtualstudent,
Were you able to meet with any success running Xen on RPi-3 ?
Thanks.
stewdk
Thu Jul 25, 2019 4:32 pm
DornerWorks has Xen running on Raspberry Pi 4, which has a GICv2 interrupt controller. See github for build instructions https://github.com/dornerworks/xen-rpi4-builder
Xen does not have a driver for the interrupt controller on RPi3 and earlier.
ehem
Thu Sep 12, 2019 7:53 pm
Good to know. I'm likely to be trying with a RP4 so knowing it is already out there is valuable.
[citation needed] I can believe this, but the Xen wiki does mention support for the Cortex-A53. Might the Raspian kernel have virtualization support removed? Generic Debian and Ubuntu kernels include support for running under Xen.
ehem
Fri Oct 04, 2019 6:27 am
So I've now see two potentially viable approaches and am presently quite unsure of which direction to go.
First, there is https://github.com/dornerworks/xen-rpi4-builder which stewdk pointed out. This is some scripting to build a bootable Ubuntu image with Xen for the Raspberry PI 4. Since I'm planning to use a distinct, but related Linux distribution as my base this is a decent starting point. The broken HDMI and 1GB limitation need fixing, plus this looks like they're building the kernel onto the boot area of an SD card so kernel updates are an issue.
Second, there is a UEFI implementation for the RP3 and the issue of RP4 support has already been brought up https://github.com/andreiw/RaspberryPiPkg/issues/130 I like this approach since it means nearly everything can be "off-the-shelf". Difficulty is it may still need adjustments to Xen to work, though these may come out of the former.
Ugh, wavering back and forth about which way to invest time.
stewdk
Wed Oct 09, 2019 5:27 pm
Here is a list of interrupt controllers that Xen supports:
GICv2 family:
arm,cortex-a15-gic
arm,cortex-a7-gic
arm,gic-400
GICv3 family:
arm,gic-v3
Yes, Xen supports Cortex-A53 paired with one of these interrupt controllers. Unfortunately the Raspberry Pi 3 has Cortex-A53 paired with a brcm,bcm2836-l1-intc per core and brcm,bcm2836-armctrl-ic for peripheral interrupts, which are unsupported in Xen. The bcm2837 (RPi3) dts includes the 2836 dtsi linked below.
https://xenbits.xen.org/gitweb/?p=xen.g ... =HEAD#l160
https://github.com/raspberrypi/linux/bl ... m2836.dtsi
Geetha
Wed Feb 19, 2020 3:35 pm
I would like to install Xen on Raspberry pi 4 according to the instructions mentioned in READMe script of below link: https://github.com/dornerworks/xen-rpi4-builder . Will it be sufficient if I only run the shell script(./rpixen.sh) or should I install anything before starting it?
mjb296
Wed Apr 15, 2020 10:11 am
Hi, has anyone has success with the Dornerworks build? I ran the script and it appeared to work (on the second attempt with a fresh, clean install of Ubuntu). I get a 2Gb image which I copied to an SD card as suggested. I get two partitions, 128M and 1.9G, so the image contains something, but the RPi4 won't boot from it and I can't mount the partitions to see what's in them.
Does anyone have a built, working image they could provide?
mjb296
Tue Apr 21, 2020 2:25 pm
Just an update: finally got the build working. A "clean" Ubuntu installation isn't quite enough. Several other packages are needed that are not installed by default, including wall, gettext and, most importantly, dosfstools for mkfs.vfat. This doesn't halt the script, but it runs through and creates the disk image without a file system.
Other gotchas: when the Dornerworks notes say it only supports 1Gb system memory, it boots on my Pi with 4 Gb, so hopefully that just means it ignores the extra 3 Gb. However, when it says it doesn't support HDMI, it's serious - it won't even boot unless you unplug your monitor.
The other point to note (which was actually on the Dornerworks GIT issues page when I thought to look) is that the default login is: username: dornerworks, password: dornerworks.
Finally, here's the built image:
https://drive.google.com/file/d/1Y5pBtZ ... sp=sharing
ehem
Fri May 22, 2020 2:18 am
Due to reading an appropriate mailing list some work is being done to get Xen fully operational on Raspberry PI 4s. Initial work is likely to be in Xen 4.14. Right now certain individuals are pushing for it and testing the experimental patches.
In the short term though I suspect using qemu and libvirt may be a workable approach for the RP3 and RP4.
