hzak
Re: Android Pie on RPi 3B(+) with hardware acceleration
Sun May 12, 2019 12:50 am
ikk wrote:
Fri May 10, 2019 9:08 pm
hzak wrote:
Fri May 10, 2019 4:49 pm
ikk wrote:
Thu May 09, 2019 8:10 pm
Ok now i get the correct sha1sum value:
Not sure what to do now
Flash the uncompressed image
Won’t let me:
Edit: I flashed it using
blkid /dev/sda
dd if=2019_03_02_rpi3_13fa200.bin of=/dev/sda bs=4MiB
Then I followed the rest of the instructions on your video... I still get the same PHY auto negotiation error on boot up :/
Just do `dd if=2019_03_02_rpi3_13fa200.bin of=/dev/sda bs=4MiB`, then check the SD card can boot up or not.
The rest of the instructions on the video may make the SD card unbootable if you make mistakes.
PS:
`zcat 2019_03_02_rpi3_13fa200.bin.gz | sudo dd of=/dev/sda bs=4MiB status=progress` used to flash the compressed image directly to the SD card. So you don't need to use gunzip command to extract 2019_03_02_rpi3_13fa200.bin.gz.
ikk
Sun May 12, 2019 9:37 am
Won’t let me:
blkid /dev/sda
PS:
Didn’t work, I still get the same issue :(
I’m using USB boot, could it be that usb boot is not compatible?
Also, if possible, can you please try re-uploading the image to github (or any other service really)? Maybe the image on github got corrupted or something.
hzak
Sun May 12, 2019 2:53 pm
Won’t let me:
blkid /dev/sda
PS:
I did not enable USB boot. not sure.
The image is ok, please check this: https://github.com/brobwind/pie-device- ... y/issues/1
ikk
Sun May 12, 2019 3:14 pm
PS:
I’ve already tried etcher, same issue.
I’ll try flashing it into the microSD card instead of using USB boot. This’ll take some time tho because I only have 1 microSD card with raspbian installed on it, hence why I’m using USB boot for anything else. I’ll create an image of my raspbian installation as a backup, then I’ll flash the .bin android image to the microSD card and try my luck.
Fingers crossed
Update:
It worked perfectly on the microSD card!
The issue is that i need the microSD card for raspbian (don’t want to run raspbian using usb boot since it’s my main OS and I want something more low-profile, hence why i need the microSD card for it)
If you don’t mind, can you please get it to support usb boot?
TiredLife
Thu May 16, 2019 4:32 am
I feel a bit embarrassed asking this since I'm guessing it's a rather simple matter. But how would I go about rooting it? Basically I'd just want to do so to get the open gapps package on there. Or more specifically for the play store.
Bejje
Tue May 21, 2019 11:28 am
I would very much like to test the compiled image, however the download link does not work.
The download starts, but not a single byte of data downloads, and after some hour if fails, I re-try again, but nothing downloads.
Is there some alternative location for the file where I can download it from.
It's this source which I'm thinking about https://www.brobwind.com
Bejje
Tue May 21, 2019 1:39 pm
Looks like I finally got the download to start, but I only get a few kilobytes per second so it will take like 24 hours or so.
Seem like the server is hosted in China and I'm in Northern Europe.
Would be nice to have a mirror somewhere so it could be downloaded in at least less than a minute.
hzak
Tue May 21, 2019 2:51 pm
The image is eng build, you already have root access.
hzak
You can download it from github.com: https://github.com/brobwind/pie-device- ... pi3-binary
Bejje
Tue May 21, 2019 3:01 pm
Cool, that took 2 sec to download :)
Bejje
Wed May 22, 2019 8:37 am
Since this image did not include any apps like Google play store, I downloaded Play store from apkmirror and installed it.
However, there is no shortcut installed on the desktop and there is no "app drawer" to find it in so I see no way to start the store.
Any ideas?
ikk
Thu May 30, 2019 6:59 am
PS:
I’ve installed it on a MicroSD card and it worked, but whenever i try to install it on another flash stick and use usb boot, it doesn’t work and i get the error I’ve already posted above.
Can you please fix it to work on usb boot?
I only have one microSD card and i need it for raspbian.
aldostrof
Wed Jun 12, 2019 9:12 am
Hi!
I have successfully installed your Android Pie on my Raspberry Pi 3B.
Anyway, you said that this ROM already has root access: I installed some root-checkers and some apps that require rooting, but they cannot detect that root access is active.
Can you tell me more about it?
Thank you!
blakehaas
Sun Jun 23, 2019 6:23 pm
Thanks for this build!
I do notice a lot of issues with the settings app though. Looking at storage space causes force close and going into timezone settings causes force close etc.
Anyone else experience this?
hzak
Thu Jul 11, 2019 4:01 pm
Hi!
Thank you!
It's a eng build, it doesn't need root app. Why do you install these apps?
hzak
Thu Jul 11, 2019 4:03 pm
It doesn't have such problems. Which image do you installed? I checked with 2019_03_02_rpi3_13fa200.bin.gz.
cyb3rgh0st
Tue Jul 23, 2019 2:54 pm
What is the easiest way to make the data partition use the rest of the sd card. I would like more storage on my sd card. Thank you
gittubaba
Mon Jul 29, 2019 9:22 pm
Is there any way to change kernel without compiling the whole project? I compiled the kernel but but how to make that into a boot.img easily?
hzak
Sat Aug 03, 2019 4:35 pm
Just run this command on the top of the Android source code tree:
$ system/core/mkbootimg/mkbootimg  --kernel kernel-v4.14/arch/arm64/boot/Image --base 0x10000000 --pagesize 2048 --cmdline "console=ttyS0,115200 buildvariant=eng" --os_version 9 --os_patch_level 2018-09-05 --kernel_offset 0x080000 --ramdisk_offset 0x01000000 --output boot.img
gittubaba
Sun Aug 04, 2019 5:23 pm
Thanks, I was trying to run android in vga monitor via vga666 resistor circuit. I created the relevant pull request in your pie-device-brobwind-rpi3-drm_hwcomposer repository in github. With that commit and relevant kernel panel driver (I'm using simple-panel) and device overlay I successfully run android in DPI/VGA display :)
Note that the official rpi documentation and vga666 thread only applies to vc4-fkms-v3d. For vc4-kms-v3d you need a kernel panel driver, a device tree overlay for that panel driver + DPI support in hwcomposer.
mcnolimits
Sun Sep 15, 2019 3:17 pm
We can´t download or clone this Repo! Github give this message:
git-lfs/2.6.0 (GitHub; windows amd64; go 1.11.1; git 93702d75)
git version 2.19.2.windows.3
$ git-lfs.exe filter-process
Error downloading object: 2019_03_02_rpi3_13fa200.bin.gz (20078c5): Smudge error: Error downloading 2019_03_02_rpi3_13fa200.bin.gz (20078c573221e4391c16b5ed9afa54855758455f62a289948ef3f234a73e0f28): batch response: This repository is over its data quota. Purchase more data packs to restore access.
batch response
p0wder
Wed Oct 16, 2019 12:14 am
I uploaded this file to my pCloud account for anyone trying to download it..
I figured I would mirror it because it is currently unavailable for download on the GitHub page, and also because it took over 5+ hours to download from brobwind's webpage.
This is the untouched image downloaded directly from brobwind.com
Download:
http://pc.cd/9DY7
Filename:
Sha256sum:
9A57253EBF0E7CB5F974CC759F0C6C23BF6DE02AE260212BB05EEAA2D6FCA894
ProfMarcoPiovesan
Sat Nov 09, 2019 4:58 pm
Hi everybody,
I'm new in Raspberry PI 3 B world and I'm trying to connect a original brand 7'' Raspberry touchscreen display with the Android PIE 9 but the touch function doesn't work..... help :roll: !!!
I'm trying this version:
https://www.brobwind.com/archives/1541
(at the bottom page) 2018_12_02_rpi3b_4117784.zip
I tried also a lot of free Android distributions but I found a problem with the centering of the image in the touchscreen, how to center the image?
PS: only Emteria Android OS on the original touchscreen work, but it isn't free..
Many Thanks
Marco
Wizard6989
Fri Dec 06, 2019 7:52 pm
Has anyone had problems using the etcher to write the image to the sd card? The problem I'm currently having is I can seem to resize the 17th partition any time I "fix" the partitions it seems to cause something to fail and wont continue to boot. I dont know if this is related to etcher but it seems to be the only difference. I will try writing image directly to the sd card later. I want utilize the full 128gb sd card. Let me know if you have any suggestions. Also I have tried building the image and downloading the newest and all seem to have the same problem.
Wizard6989
Wed Dec 11, 2019 5:10 am
I'm pretty sure the dependencies are broken for building from source, here is the fix that worked for me.
dosfstools version 4.1 is not compatible with the build scripts, you will need to downgrade to dosfstools 3.0.28.
I also needed to reinstall the python packages for it to work.
sudo apt-get install python-pip libyaml-dev curl
curl http://archive.ubuntu.com/ubuntu/pool/m ... _amd64.deb -o dosfstools_3.0.28-2ubuntu0.1_amd64.deb
sudo apt install ./dosfstools_3.0.28-2ubuntu0.1_amd64.deb
sudo pip install setuptools prettytable Mako pyaml dateutils --upgrade
Let me know if this helps you, I am still having problems with fixing the gpt table when I go to resize partion 17 userdata, this maybe a possible bug. I am currently trying a new work around
Return to “Android”
