I have been using Wicd for my WiFi management and carl9170-1.fw for my D-Link wifi dongle. The dongle is plugged into powered hub. The distro is Raspbian. The setup has worked flawlessly for days.
All of a sudden I began getting these errors after each start up:
"Could not connect to wicd's D-bus interface. Check the wicd log for error message."
Followed by
"The wicd daemon has shut down. The UI will not function properly until it is restarted."
I checked my RPi input voltage during boot on the oscilloscope. Lowest sag was 4.791V. Nominal voltage is ca 4.8V. Measured at the GPIO header.
Looking for things to check to resolve the issue.
Thanks.
Kind regards,
Marius
EDIT: I checked the Wicd.log, it turns out the log hasnt been written to in a while, and contains no logged information from during the incidents.
EDIT2: When I close Wicd, and start the application from LDE->internet->wicd the application starts without errors.
