hello, i need to use the hardware pwm, but all the code i find uses wiringpi or others libraries, is there a guide to set the hardware pwm without the use of wiringpi?
thank you
The original Raspberry Pi Model A and B version B1 was a $35 single board computer with a 26-pin General Purpose Input/Output (GPIO) connector and this carries a set of signals and buses. There are 8 general purpose digital I/O pins – these can be programmed as either digital outputs or inputs. Two of these pins (on 40-pin Pi’s, just one on 26-pin Pi’s) can be designated for hardware PWM output too. Additionally there is a 2-wire I2C interface and a 4-wire SPI interface (with a 2nd select line, making it 5 pins in total) and the serial UART with a further 2 pins.
yes, i've seen, i will try, but the main idea of the project is to be indipendent from third part librariesDougieLawson wrote: ↑Wed Jan 23, 2019 7:37 pmHave you looked at pigpio and pigpiod?
http://abyz.me.uk/rpi/pigpio/
// cc pwm.c -Wall -o pwm
// ./pwm
// Restarts via sudo if run as user pi.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <fcntl.h>
#include <stdint.h>
#include <unistd.h>
#include <sys/mman.h>
#include <sys/types.h>
#define PI_1_PERIPHERAL_BASE 0x20000000
#define PI_2_PERIPHERAL_BASE 0x3F000000
#define GPIO_BASE 0x200000
#define PWM_BASE 0x20C000
#define CLOCK_BASE 0x101000
/* uint32_t pointer offsets to registers in the PWM address map are byte
| offset / 4.
#define PWM_CTL_REG (0x0 / 4)
#define CTL_REG_RESET_STATE 0
#define CTL_REG_PWM1_ENABLE 1
#define CTL_REG_MSEN1 0x80
#define CTL_REG_PWM1_MS_MODE (CTL_REG_PWM1_ENABLE | CTL_REG_MSEN1)
#define CTL_REG_PWM2_ENABLE 0x100
#define CTL_REG_MSEN2 0x8000
#define CTL_REG_PWM2_MS_MODE (CTL_REG_PWM2_ENABLE | CTL_REG_MSEN2)
#define PWM_RNG1_REG (0x10 / 4)
#define PWM_DAT1_REG (0x14 / 4)
#define PWM_RNG2_REG (0x20 / 4)
#define PWM_DAT2_REG (0x24 / 4)
#define PWM_CLOCK_HZ 19200000.0
#define PWM_RESOLUTION 0.000005 // 5 usec resolution
#define PWM_MSEC_TO_COUNT(ms) ((ms) / PWM_RESOLUTION / 1000.0)
#define PULSE_WIDTH_RESOLUTION .00001 // .01 msec resolution
/* PWM clock manager registers are not in the BCM2835-ARM-Peripherals pdf,
| but are defined (as byte addresses CM_PWMDIV & CM_PWMCTL) in the addendum:
| http://www.scribd.com/doc/127599939/BCM2835-Audio-clocks
| These REG defines here give uint32_t pointer offsets from clock base.
#define CM_PASSWORD 0x5A000000
#define CM_PWMCTL_REG (0xa0 / 4)
#define PWMCTL_BUSY 0x80 // Read only
#define PWMCTL_KILL 0x20
#define PWMCTL_ENABLE 0x10
#define PWMCTL_SRC_OSC 0x1
#define CM_PWMDIV_REG (0xa4 / 4)
#define PWMDIV_DIVI(divi) (divi << 12) // bits 23-12, max 4095
#define GPSET_REG (0x1c / 4)
#define GPCLR_REG (0x28 / 4)
#define GPLEV_REG (0x34 / 4)
#define GPPUD_REG (0x94 / 4)
#define PUD_DOWN 1
#define PUD_UP 2
#define GPPUDCLK_REG (0x98 / 4)
#define MAX(a,b) (((a) > (b)) ? (a) : (b))
#define MIN(a,b) (((a) < (b)) ? (a) : (b))
/* Pointers to mapped peripheral registers.
static volatile uint32_t *gpio_mmap;
static volatile uint32_t *pwm_mmap;
static volatile uint32_t *clock_mmap;
int servo_pan_gpio = 18;
int servo_tilt_gpio = 19;
int servo_pan_invert = 0;
int servo_tilt_invert = 0;
/* Servo pulse width units are .01 msec (E.g. so width = 150 is 1.5 msec)
void
servo_pulse_width(int pwm_channel, int width, int invert)
uint32_t count;
int reg;
if (pwm_channel == 1)
reg = PWM_DAT1_REG;
else if (pwm_channel == 2)
reg = PWM_DAT2_REG;
else
return;
if (invert)
width = 300 - width; // 150 msec is center
count = (uint32_t)(PULSE_WIDTH_RESOLUTION / PWM_RESOLUTION) * width;
if (count > PWM_MSEC_TO_COUNT(3.0))
count = PWM_MSEC_TO_COUNT(3.0);
if (count < PWM_MSEC_TO_COUNT(0.5))
count = PWM_MSEC_TO_COUNT(0.5);
*(pwm_mmap + reg) = count;
void
gpio_to_channel(int gpio, int *channel, int *altfn)
int chan = -1, alt = -1;
if (gpio == 12 || gpio == 18)
chan = 1;
if (gpio == 18)
alt = 5;
if (gpio == 13 || gpio == 19)
chan = 2;
if (gpio == 19)
alt = 5;
if (channel)
*channel = chan;
if (altfn)
*altfn = alt;
void
servo_move(int pan, int tilt, int delay)
static float pan_cur, tilt_cur;
float pan_inc, tilt_inc;
int pan_channel, tilt_channel;
int pan_delta, tilt_delta, max_delta, i;
gpio_to_channel(servo_pan_gpio, &pan_channel, NULL);
gpio_to_channel(servo_tilt_gpio, &tilt_channel, NULL);
if (pan_cur == 0)
pan_cur = (float)pan;
if (tilt_cur == 0)
tilt_cur = (float)tilt;
pan_delta = pan - pan_cur;
tilt_delta = tilt - tilt_cur;
max_delta = MAX(abs(pan_delta), abs(tilt_delta));
pan_inc = (float)max_delta / (float)pan_delta;
tilt_inc = (float)max_delta / (float)tilt_delta;
for (i = 1; i < max_delta && delay > 0; ++i)
pan_cur += pan_inc;
tilt_cur += tilt_inc;
servo_pulse_width(pan_channel, (int)pan_cur, servo_pan_invert);
servo_pulse_width(tilt_channel, (int)tilt_cur, servo_tilt_invert);
usleep(delay * 1000);
servo_pulse_width(pan_channel, pan, servo_pan_invert);
servo_pulse_width(tilt_channel, tilt, servo_tilt_invert);
/* BCM2835 ARM Peripherals pg 91, 10 gpios per gpfsel with mode bits:
static unsigned int gpfsel_mode_table[] =
/* in out alt0 alt1 alt2 alt3 alt4 alt5 */
0b000, 0b001, 0b100, 0b101, 0b110, 0b111, 0b011, 0b010
void
gpio_alt_function(int pin, int altfn)
int gpfsel = pin / 10,
shift = (pin % 10) * 3;
if (altfn >= 0 && altfn <= 5)
*(gpio_mmap + gpfsel) = (*(gpio_mmap + gpfsel) & ~(0x7 << shift))
| (gpfsel_mode_table[altfn + 2] << shift);
void
gpio_set_mode(int pin, int mode) /* mode 0:input 1:output */
if (mode == 0 || mode == 1)
| (gpfsel_mode_table[mode] << shift);
/* BCM2835 ARM Peripherals pg 101 - PUD sequence
void
gpio_set_pud(int pin, int pud)
int gp_reg = GPPUDCLK_REG + ((pin > 31) ? 1 : 0);
if (pud != PUD_DOWN && pud != PUD_UP)
return;
*(gpio_mmap + GPPUD_REG) = pud;
usleep(2); // min wait of 150 cycles
*(gpio_mmap + gp_reg) = 1 << (pin & 0x1f);
usleep(2);
*(gpio_mmap + GPPUD_REG) = 0;
*(gpio_mmap + gp_reg) = 0;
int
gpio_read(int pin)
int gp_reg = GPLEV_REG + ((pin > 31) ? 1 : 0);
return (*(gpio_mmap + gp_reg) & (1 << (pin & 0x1f)) ? 1 : 0 );
void
gpio_write(int pin, int level)
int gp_reg = ((level == 0) ? GPCLR_REG : GPSET_REG) + ((pin > 31) ? 1 : 0);
void
init_peripherals(int peripheral_base)
int fd;
uint32_t divi;
if ((fd = open("/dev/mem", O_RDWR|O_SYNC) ) < 0)
fprintf(stderr, "/dev/mem open failed: %m\n");
exit (-1);
gpio_mmap = (uint32_t *) mmap(NULL, 0x100, PROT_READ|PROT_WRITE, MAP_SHARED,
fd, peripheral_base + GPIO_BASE);
pwm_mmap = (uint32_t *) mmap(NULL, 0x100, PROT_READ|PROT_WRITE, MAP_SHARED,
fd, peripheral_base + PWM_BASE);
clock_mmap = (uint32_t *) mmap(NULL, 0x100, PROT_READ|PROT_WRITE, MAP_SHARED,
fd, peripheral_base + CLOCK_BASE);
close(fd);
if (pwm_mmap == MAP_FAILED || clock_mmap == MAP_FAILED)
exit(-1);
gpio_alt_function(18, 5);
gpio_alt_function(19, 5);
/* Kill clock (waiting for busy flag does not work)
*(clock_mmap + CM_PWMCTL_REG) = CM_PASSWORD | PWMCTL_KILL;
usleep(10);
/* PWM clock is 19.2MHz. Set the divisor so each count gives the resolution
| we want.
divi = (uint32_t) (PWM_CLOCK_HZ * PWM_RESOLUTION);
*(clock_mmap + CM_PWMDIV_REG) = CM_PASSWORD | PWMDIV_DIVI(divi);
*(clock_mmap + CM_PWMCTL_REG) = CM_PASSWORD | PWMCTL_ENABLE | PWMCTL_SRC_OSC;
/* Turn off PWM - reset state.
*(pwm_mmap + PWM_CTL_REG) = CTL_REG_RESET_STATE;
usleep(50);
/* E.g. Range of 20 msec -> 4000 counts at 5 usec PWM resolution */
*(pwm_mmap + PWM_RNG1_REG) = (uint32_t) PWM_MSEC_TO_COUNT(20);
*(pwm_mmap + PWM_RNG2_REG) = (uint32_t) PWM_MSEC_TO_COUNT(20);
/* PWM channels run in M/S mode so pulse width is count of data and
| period is count of range.
*(pwm_mmap + PWM_CTL_REG) = CTL_REG_PWM1_MS_MODE | CTL_REG_PWM2_MS_MODE;
int
pi_model(void)
FILE *f;
int model = 1;
char buf[200], arm[32];
if ((f = fopen("/proc/cpuinfo", "r")) == NULL)
return 0;
while (fgets(buf, sizeof(buf), f) != NULL)
if (sscanf(buf, "model name %*s %31s", arm) > 0)
if (!strcmp(arm, "ARMv7"))
model = 2;
break;
fclose(f);
return model;
int
main(int argc, char **argv)
char buf[200];
int model, peripheral_base;
model = pi_model();
if (model == 2)
peripheral_base = PI_2_PERIPHERAL_BASE;
else
peripheral_base = PI_1_PERIPHERAL_BASE;
printf("model: %d\n", model);
printf("uid:%d euid:%d gid:%d\n", getuid(), geteuid(), getgid());
if (getuid() != 0)
snprintf(buf, 200, "sudo %s", argv[0]);
system(buf);
exit(0);
printf(" uid:%d euid:%d gid:%d\n", getuid(), geteuid(), getgid());
init_peripherals(peripheral_base);
setgid(27);
setuid(1000);
while (1)
/* servo pulse width units are .01 msec
servo_move(150, 150, 0);
sleep(1);
servo_move(120, 120, 50);
sleep(1);
servo_move(180, 180, 10);
sleep(1);
servo_move(120, 160, 30);
sleep(1);
#if 0
servo_pulse_width(1, 150);
servo_pulse_width(2, 150);
sleep(1);
servo_pulse_width(1, 100);
servo_pulse_width(2, 200);
sleep(1);
for (i = 100; i <= 200; i += 1)
servo_pulse_width(1, i);
servo_pulse_width(2, 300 - i);
usleep(30000);
sleep(1);
#endif
return 0;
you're wrong. It supports both PWM channels.birddseedd wrote: ↑Thu Jan 24, 2019 5:49 pmI was going to ask a simular question. perhraps this will be a good place to ask.
i'm wanting to use pwm to control 2 motors. but it seems the wiringpi library only allows for 1 pin? thus controlling only one motor. I need to control 2. correct me if im wrong
My website is old.
this is from their website.
ok! thanks for the suggestion
great!, thanks for your help!!billw wrote: When I added builtin servo control to my camera app I also did not want other library dependencies. Here's a standalone hardware
pwm test program I wrote at the time.
It is structured to control servos with pulse widths between 1 ms and 2 ms and it restarts via sudo if run as normal pi user,
Pins 18 and 19 are hardwired in the code but can be edited to 12 and 13 (probably in a couple of places).
Maybe it can be useful to you as a starting point.
// cc pwm.c -Wall -o pwm // ./pwm // Restarts via sudo if run as user pi. #include <stdio.h> #include <string.h> #include <stdlib.h> #include <fcntl.h> #include <stdint.h> #include <unistd.h> #include <sys/mman.h> #include <sys/types.h> #define PI_1_PERIPHERAL_BASE 0x20000000 #define PI_2_PERIPHERAL_BASE 0x3F000000 #define GPIO_BASE 0x200000 #define PWM_BASE 0x20C000 #define CLOCK_BASE 0x101000 /* uint32_t pointer offsets to registers in the PWM address map are byte | offset / 4. */ #define PWM_CTL_REG (0x0 / 4) #define CTL_REG_RESET_STATE 0 #define CTL_REG_PWM1_ENABLE 1 #define CTL_REG_MSEN1 0x80 #define CTL_REG_PWM1_MS_MODE (CTL_REG_PWM1_ENABLE | CTL_REG_MSEN1) #define CTL_REG_PWM2_ENABLE 0x100 #define CTL_REG_MSEN2 0x8000 #define CTL_REG_PWM2_MS_MODE (CTL_REG_PWM2_ENABLE | CTL_REG_MSEN2) #define PWM_RNG1_REG (0x10 / 4) #define PWM_DAT1_REG (0x14 / 4) #define PWM_RNG2_REG (0x20 / 4) #define PWM_DAT2_REG (0x24 / 4) #define PWM_CLOCK_HZ 19200000.0 #define PWM_RESOLUTION 0.000005 // 5 usec resolution #define PWM_MSEC_TO_COUNT(ms) ((ms) / PWM_RESOLUTION / 1000.0) #define PULSE_WIDTH_RESOLUTION .00001 // .01 msec resolution /* PWM clock manager registers are not in the BCM2835-ARM-Peripherals pdf, | but are defined (as byte addresses CM_PWMDIV & CM_PWMCTL) in the addendum: | http://www.scribd.com/doc/127599939/BCM2835-Audio-clocks | These REG defines here give uint32_t pointer offsets from clock base. */ #define CM_PASSWORD 0x5A000000 #define CM_PWMCTL_REG (0xa0 / 4) #define PWMCTL_BUSY 0x80 // Read only #define PWMCTL_KILL 0x20 #define PWMCTL_ENABLE 0x10 #define PWMCTL_SRC_OSC 0x1 #define CM_PWMDIV_REG (0xa4 / 4) #define PWMDIV_DIVI(divi) (divi << 12) // bits 23-12, max 4095 #define GPSET_REG (0x1c / 4) #define GPCLR_REG (0x28 / 4) #define GPLEV_REG (0x34 / 4) #define GPPUD_REG (0x94 / 4) #define PUD_DOWN 1 #define PUD_UP 2 #define GPPUDCLK_REG (0x98 / 4) #define MAX(a,b) (((a) > (b)) ? (a) : (b)) #define MIN(a,b) (((a) < (b)) ? (a) : (b)) /* Pointers to mapped peripheral registers. */ static volatile uint32_t *gpio_mmap; static volatile uint32_t *pwm_mmap; static volatile uint32_t *clock_mmap; int servo_pan_gpio = 18; int servo_tilt_gpio = 19; int servo_pan_invert = 0; int servo_tilt_invert = 0; /* Servo pulse width units are .01 msec (E.g. so width = 150 is 1.5 msec) */ void servo_pulse_width(int pwm_channel, int width, int invert) { uint32_t count; int reg; if (pwm_channel == 1) reg = PWM_DAT1_REG; else if (pwm_channel == 2) reg = PWM_DAT2_REG; else return; if (invert) width = 300 - width; // 150 msec is center count = (uint32_t)(PULSE_WIDTH_RESOLUTION / PWM_RESOLUTION) * width; if (count > PWM_MSEC_TO_COUNT(3.0)) count = PWM_MSEC_TO_COUNT(3.0); if (count < PWM_MSEC_TO_COUNT(0.5)) count = PWM_MSEC_TO_COUNT(0.5); *(pwm_mmap + reg) = count; } void gpio_to_channel(int gpio, int *channel, int *altfn) { int chan = -1, alt = -1; if (gpio == 12 || gpio == 18) { chan = 1; if (gpio == 18) alt = 5; } if (gpio == 13 || gpio == 19) { chan = 2; if (gpio == 19) alt = 5; } if (channel) *channel = chan; if (altfn) *altfn = alt; } void servo_move(int pan, int tilt, int delay) { static float pan_cur, tilt_cur; float pan_inc, tilt_inc; int pan_channel, tilt_channel; int pan_delta, tilt_delta, max_delta, i; gpio_to_channel(servo_pan_gpio, &pan_channel, NULL); gpio_to_channel(servo_tilt_gpio, &tilt_channel, NULL); if (pan_cur == 0) pan_cur = (float)pan; if (tilt_cur == 0) tilt_cur = (float)tilt; pan_delta = pan - pan_cur; tilt_delta = tilt - tilt_cur; max_delta = MAX(abs(pan_delta), abs(tilt_delta)); pan_inc = (float)max_delta / (float)pan_delta; tilt_inc = (float)max_delta / (float)tilt_delta; for (i = 1; i < max_delta && delay > 0; ++i) { pan_cur += pan_inc; tilt_cur += tilt_inc; servo_pulse_width(pan_channel, (int)pan_cur, servo_pan_invert); servo_pulse_width(tilt_channel, (int)tilt_cur, servo_tilt_invert); usleep(delay * 1000); } pan_cur = (float)pan; tilt_cur = (float)tilt; servo_pulse_width(pan_channel, pan, servo_pan_invert); servo_pulse_width(tilt_channel, tilt, servo_tilt_invert); } /* BCM2835 ARM Peripherals pg 91, 10 gpios per gpfsel with mode bits: */ static unsigned int gpfsel_mode_table[] = { /* in out alt0 alt1 alt2 alt3 alt4 alt5 */ 0b000, 0b001, 0b100, 0b101, 0b110, 0b111, 0b011, 0b010 }; void gpio_alt_function(int pin, int altfn) { int gpfsel = pin / 10, shift = (pin % 10) * 3; if (altfn >= 0 && altfn <= 5) *(gpio_mmap + gpfsel) = (*(gpio_mmap + gpfsel) & ~(0x7 << shift)) | (gpfsel_mode_table[altfn + 2] << shift); } void gpio_set_mode(int pin, int mode) /* mode 0:input 1:output */ { int gpfsel = pin / 10, shift = (pin % 10) * 3; if (mode == 0 || mode == 1) *(gpio_mmap + gpfsel) = (*(gpio_mmap + gpfsel) & ~(0x7 << shift)) | (gpfsel_mode_table[mode] << shift); } /* BCM2835 ARM Peripherals pg 101 - PUD sequence */ void gpio_set_pud(int pin, int pud) { int gp_reg = GPPUDCLK_REG + ((pin > 31) ? 1 : 0); if (pud != PUD_DOWN && pud != PUD_UP) return; *(gpio_mmap + GPPUD_REG) = pud; usleep(2); // min wait of 150 cycles *(gpio_mmap + gp_reg) = 1 << (pin & 0x1f); usleep(2); *(gpio_mmap + GPPUD_REG) = 0; *(gpio_mmap + gp_reg) = 0; } int gpio_read(int pin) { int gp_reg = GPLEV_REG + ((pin > 31) ? 1 : 0); return (*(gpio_mmap + gp_reg) & (1 << (pin & 0x1f)) ? 1 : 0 ); } void gpio_write(int pin, int level) { int gp_reg = ((level == 0) ? GPCLR_REG : GPSET_REG) + ((pin > 31) ? 1 : 0); *(gpio_mmap + gp_reg) = 1 << (pin & 0x1f); } void init_peripherals(int peripheral_base) { int fd; uint32_t divi; if ((fd = open("/dev/mem", O_RDWR|O_SYNC) ) < 0) { fprintf(stderr, "/dev/mem open failed: %m\n"); exit (-1); } gpio_mmap = (uint32_t *) mmap(NULL, 0x100, PROT_READ|PROT_WRITE, MAP_SHARED, fd, peripheral_base + GPIO_BASE); pwm_mmap = (uint32_t *) mmap(NULL, 0x100, PROT_READ|PROT_WRITE, MAP_SHARED, fd, peripheral_base + PWM_BASE); clock_mmap = (uint32_t *) mmap(NULL, 0x100, PROT_READ|PROT_WRITE, MAP_SHARED, fd, peripheral_base + CLOCK_BASE); close(fd); if (pwm_mmap == MAP_FAILED || clock_mmap == MAP_FAILED) exit(-1); gpio_alt_function(18, 5); gpio_alt_function(19, 5); /* Kill clock (waiting for busy flag does not work) */ *(clock_mmap + CM_PWMCTL_REG) = CM_PASSWORD | PWMCTL_KILL; usleep(10); /* PWM clock is 19.2MHz. Set the divisor so each count gives the resolution | we want. */ divi = (uint32_t) (PWM_CLOCK_HZ * PWM_RESOLUTION); *(clock_mmap + CM_PWMDIV_REG) = CM_PASSWORD | PWMDIV_DIVI(divi); *(clock_mmap + CM_PWMCTL_REG) = CM_PASSWORD | PWMCTL_ENABLE | PWMCTL_SRC_OSC; /* Turn off PWM - reset state. */ *(pwm_mmap + PWM_CTL_REG) = CTL_REG_RESET_STATE; usleep(50); /* E.g. Range of 20 msec -> 4000 counts at 5 usec PWM resolution */ *(pwm_mmap + PWM_RNG1_REG) = (uint32_t) PWM_MSEC_TO_COUNT(20); *(pwm_mmap + PWM_RNG2_REG) = (uint32_t) PWM_MSEC_TO_COUNT(20); /* PWM channels run in M/S mode so pulse width is count of data and | period is count of range. */ *(pwm_mmap + PWM_CTL_REG) = CTL_REG_PWM1_MS_MODE | CTL_REG_PWM2_MS_MODE; } int pi_model(void) { FILE *f; int model = 1; char buf[200], arm[32]; if ((f = fopen("/proc/cpuinfo", "r")) == NULL) return 0; while (fgets(buf, sizeof(buf), f) != NULL) { if (sscanf(buf, "model name %*s %31s", arm) > 0) { if (!strcmp(arm, "ARMv7")) model = 2; break; } } fclose(f); return model; } int main(int argc, char **argv) { char buf[200]; int model, peripheral_base; model = pi_model(); if (model == 2) peripheral_base = PI_2_PERIPHERAL_BASE; else peripheral_base = PI_1_PERIPHERAL_BASE; printf("model: %d\n", model); printf("uid:%d euid:%d gid:%d\n", getuid(), geteuid(), getgid()); if (getuid() != 0) { snprintf(buf, 200, "sudo %s", argv[0]); system(buf); exit(0); } printf(" uid:%d euid:%d gid:%d\n", getuid(), geteuid(), getgid()); init_peripherals(peripheral_base); setgid(27); setuid(1000); printf(" uid:%d euid:%d gid:%d\n", getuid(), geteuid(), getgid()); while (1) { /* servo pulse width units are .01 msec */ servo_move(150, 150, 0); sleep(1); servo_move(120, 120, 50); sleep(1); servo_move(180, 180, 10); sleep(1); servo_move(120, 160, 30); sleep(1); #if 0 servo_pulse_width(1, 150); servo_pulse_width(2, 150); sleep(1); servo_pulse_width(1, 100); servo_pulse_width(2, 200); sleep(1); for (i = 100; i <= 200; i += 1) { servo_pulse_width(1, i); servo_pulse_width(2, 300 - i); usleep(30000); } sleep(1); #endif } return 0; }
