snazzify
GPIO-POWEROFF: Is it safe to immediately cut power off when pin goes LOW?
Thu Jan 17, 2019 1:48 am
I'm using the following code to detect shutdown so i can cut off power.
dtoverlay=gpio-poweroff,gpiopin=10,active_low=1
My real concern is, is it safe to immediately cut off power when the GPIO pin goes low? Or do I need some delay like maybe 1-3 seconds or something?
Re: GPIO-POWEROFF: Is it safe to immediately cut power off when pin goes LOW?
Thu Jan 17, 2019 1:54 am
Yes, it is safe. You should see the 10 flashes of teh ACT LED just before the pin changes state.
snazzify
Thu Jan 17, 2019 2:12 am
I can only see about 3-4 blinks of the ACT LED when issuing
sudo shutdown -h now
but if I shutdown without using the GPIO-POWEROFF the ACT LED certainly blinks more about 10 flashes.
Paul Hutch
Mon Jan 21, 2019 2:45 pm
I was trying out the gpio-poweroff overlay this weekend and I saw the same thing. When I use the overlay, instead of the normal power off activity LED flashing, I get just a couple quick flashes.
I monitored the current draw and found that when using the overlay on the latest updated distro it does not appear to shutdown correctly.
For reference:
RasPi 3b+
At idle the current consumption is ~0.4A
External LED on pin 25
The only configuration difference between tests is in config.txt
Config 1 (gpio=25=op,dh)
Config 2 (dtoverlay=gpio-poweroff,gpiopin=25,active_low=1)
Both configurations turn on the LED @ power up and turn off the LED @ power down
Here's what I'm seeing at power off (sudo poweroff)
Config 1:
Ten long flashes of the activity LED
Power consumption drops to ~0.1A
Config 2:
Three quick flashes of the activity LED
Power consumption goes up to ~0.7A
Based on the descriptions I've read this does not seem to be the correct result when using the gpio-poweroff overlay.
bk4nt
Tue Dec 17, 2019 10:53 pm
+1 on RPi 4 Linux raspberrypi 4.19.75-v7l+
I have also an OLED display and corresponding stop/start service which nicely turns of that display on an init 0 if I do not activate dtoverlay gpio-poweroff option.
As soon as I add dtoverlay gpio-poweroff feature, I do see the corresponding GPIO pin state change like expected (I added a LED on it), but my OLED display isn't blanked anymore on init 0.
So I assume the halt scripts are at some point interrupted when dtoverlay gpio-poweroff feature is activated. That seems unsafe.
bk4nt
Wed Dec 18, 2019 8:15 pm
I made further tests. I was using the Pi headless, via ssh only, so I didn't notice... that my kernel each time crashes in the middle of shutdown process as soon I activate gpio-powerdown option (but the GPIO pin behaves like expected).
I wouldn't have noticed it either if I would already have external power cut off components. It would so just crash and cut the power.
bk4nt
Fri Dec 20, 2019 10:15 pm
Some quick answers... might help
GPIO state change indicates that the CPU just went to inactive state (system was halted). So it is then safe to cut the power.
I noticed a kernel panic (I currently haven't power cut off hardware installed). If one waits up to 3 seconds instead of cutting the power in delay, this "panic" will be triggered, as an indicator. This is expected and described here:
https://www.kernel.org/doc/Documentatio ... weroff.txt
gpio-poweroff for Raspberry being described here:
https://raw.githubusercontent.com/raspb ... ays/README
That overlay for GPIO triggered poweroff runs different code, so green and red LED don't flash the same way.
Moreover, I noticed some of my codes didn't stop like I expected on poweroff with that feature enabled. They where just crashing/interrupted. But this was because my codes didn't handle the correct signals, I had to add SIGHUP to delay Linux shutdown untill they finished their execution.
The basic code I used for testings, makes a LED blink slowly, then faster after SIGHUP, for some 10 seconds (during which system halt gets by the way paused):
import RPi.GPIO as GPIO
import signal
import sys
import time
GPIO_LED   = 20
def signal_handler(sig, frame):
        GPIO.output(GPIO_LED, GPIO.HIGH)
        for y in range(0, int(10.0/0.05)):
                GPIO.output(GPIO_LED, GPIO.LOW)
                time.sleep(0.05)
                time.sleep(0.05)
        GPIO.cleanup()
        sys.exit(0)
signal.signal(signal.SIGINT, signal_handler)
signal.signal(signal.SIGTERM, signal_handler)
signal.signal(signal.SIGHUP, signal_handler)
GPIO.setmode(GPIO.BCM)
GPIO.setup(GPIO_LED, GPIO.OUT)
while True:
        time.sleep(1)
        time.sleep(1)
Return to “Advanced users”
