mrdebug
Raspberry Pi and RS-485
Tue Jan 15, 2019 8:48 am
Hi, could someone suggest me a i2c / spi to 485 interface, well supported by Raspberry pi, that has personally tested?
I need something that calculates the direction (enable) signal automatically.
www. ???
www. ???
GMT+1
Skype: mrdebug
mahjongg
Re: Raspberry Pi and RS-485
Tue Jan 15, 2019 12:58 pm
RS-485 is a balanced serial signal, with point to multi-point capabilities. The bus master should determine the direction of the transfers.
A PI can be a master using the USART for the serial I/O and a GPIO for bus direction.
https://en.wikipedia.org/wiki/RS-485
there is no system that "calculates" the bus direction AFAIK.
mrdebug
Tue Jan 15, 2019 1:11 pm
No, I can't use gpio.
Do you have experience with max13487eesa+?
www. ???
www. ???
GMT+1
Skype: mrdebug
danjperron
Tue Jan 15, 2019 4:51 pm
I made a lot of testing using the RS-485 with different methods.
Why I2c or SPI?
The simplest way is USB. They are so cheap that is not worth re-invent them.
https://www.dx.com/p/usb-to-rs485-adapt ... en-2039807
I even made a small cpu to take care of the switching. https://github.com/danjperron/RS485switch
Have a look at those posts.
viewtopic.php?f=98&t=224533&hilit=rs+485#p1383709
viewtopic.php?f=44&t=75189&hilit=rs+485#p563861
