Onira
/etc/network/interfaces - HOW ??
Sat Nov 17, 2012 9:12 pm
How to configure this file?
I edited it and ssh -X got disabled...
Cogito ergo sum
glennwiz
Re: /etc/network/interfaces - HOW ??
Sat Nov 17, 2012 9:55 pm
you prolly dident disable ssh, you fracked up the setting neede for the network card to get an ip.
set the card to use dhcp again and it shold work, use that to make sure it works.
this is the default rpi setup
glennwiz@raspberrypi ~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
if you want to set static use somthing like:
➜ glennwiz-main ~ cat /etc/network/interfaces
auto lo
auto eth0
iface eth0 inet static
address 192.168.0.105
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
gateway 192.168.0.1
dns-nameservers 8.8.8.8 8.8.4.4
➜ glennwiz-main ~
joan
Try
man interfaces
for some examples.
Onira
Sun Nov 18, 2012 10:25 am
I have
  • auto wlan0
    iface wlan0 inet dhcp
    wpa-ssid "MySSID"
    wpa-psk "MyPASS"
and it doesn't work
ssh works but X11Forwarding does NOT
Cogito ergo sum
joan
Sun Nov 18, 2012 11:25 am
I doubt if X forwarding has got anything to do with /etc/network/interfaces.
What are you trying to run and what error message do you get?
Onira
Sun Nov 18, 2012 7:23 pm
leafpad or xclock
$ leafpad
Can't open display
Cogito ergo sum
joan
Sun Nov 18, 2012 8:19 pm
Try the command
env
It should have entries for SSH_CONNECTION and DISPLAY.
Do they look sensible?
Onira
Mon Nov 19, 2012 10:09 am
aye,
DISPLAY and SSH_CONNECTION look good
Cogito ergo sum
rtalkivi
Wed Apr 24, 2013 6:24 pm
It's possible to use ssh to launch fbi and display images on a remote terminal, for example:
sudo fbi -noverbose -m 1920x1080 -a -t 5 -T 2 *jpg
The -T 2 is the key part here that tells it to display the images on "tty2"
