zimzia
Pi 3b+ lost Capacitor on PCB
Mon Jan 14, 2019 9:46 pm
On my pcb is missing these 2 capacitors, so be it?
Burngate
Re: Pi 3b+ lost Capacitor on PCB
Tue Jan 15, 2019 11:05 am
The resolution is to low for me to see what's missing.
What effect are you seeing?
zimzia
Tue Jan 15, 2019 2:44 pm
I corrected the photo, it seems to me that everything works, can it be from GPIO?
mahjongg
Tue Jan 15, 2019 6:40 pm
Only the designer knows.
There are no component references on the board, and there is no schematic, the PI is NOT "open source hardware".
an educated guess is that these are decoupling caps, 100nF 6V3 0402, but as I said I'm guessing.
Were the capacitors rubbed off, or never mounted?
zimzia
Tue Jan 15, 2019 7:01 pm
I looked closely, missing 6 elements, never mounted, 5 capacitor 1 rezistor. PCB model FCC ID 2ABCB-RPI3BP, IC 20953-RPI3P, 3.3 OC-138, 94V-0H.
hippy
Tue Jan 15, 2019 9:28 pm
Contact who you bought it from and arrange to get a replacement.
HawaiianPi
Tue Jan 15, 2019 10:47 pm
It's normal to have empty component locations on a complex PCB. There are various reasons for that, but almost every large PCB will have at least a few empty spots (and those may change over time or production runs).
Not sure about the 2 you asked about in the OP (mine has them). Only the RPi designers or engineers can say for certain.
Burngate
Wed Jan 16, 2019 10:09 am
The right-hand end of each appears to be ground; that would tally with mahjongg's guess
Where the left-hand ends go I have no idea. Not, apparently, to the GPIOs.
6by9
Wed Jan 16, 2019 10:52 am
Neither are populated on at least one of my boards.
I can check with the hardware guys, but I wouldn't worry about it. There will be deliberate minor variations between builds as tweaks are made to reduce the BOM, none of which will affect the functionality.
hippy
Wed Jan 16, 2019 11:49 am
I guess this takes us back to the "undocumented change" issue.
With two boards, where one has things missing which are on the other, no one outside RPT knows if that's some sort of assembly error or intended, whether it's something to worry over or not.
To determine which it is means having to find someone who can find someone within RPT who can find the definitive answer.
There has to be some better, less resource hungry, way than that
6by9
Wed Jan 16, 2019 12:25 pm
Checked. Yes, they're just small decoupling caps that were found to be unnecessary and therefore removed from the BOM. There are also at least four around the PMIC also removed.
You've bought a board for which is provided a guarantee that it will work. It's not an open design.
Unless you actually have issues (in which case take it up through the supply chain), don't worry about it.
bensimmo
Wed Jan 16, 2019 12:28 pm
Do RPT alter the design or is it Farnell etc, the licensed makers, that choose to reduce and redesign these small bits and bobs as needed ?
6by9
Wed Jan 16, 2019 12:32 pm
RPT.
Burngate
Wed Jan 16, 2019 5:56 pm
... they're just small decoupling caps that were found to be unnecessary and therefore removed from the BOM. There are also at least four around the PMIC also removed.
I wonder how it's determined that they're unnecessary.
Does someone take a representative sample of boards - say, a thousand - and remove odd components here and there, just to see what happens?
This seems unlikely.
Or does someone read the fine print in the datasheets and realise they got it wrong first time round?
Similarly unlikely.
Is my idle wondering about this sort of thing a waste of my time?
That's very much more likely.
davidcoton
Wed Jan 16, 2019 6:09 pm
Similarly unlikely.
My guess is that the original design allows for different manufacturers or versions of one or more ICs. The capacitors are not fitted if the IC variant used doesn't need it, and obviously there is benefit (to RPT) in sourcing those versions (price otherwise being equal). It's quite possible that some early batches have to be built with the ICs that do require extra decoupling, until the supply chain becomes established and stable.
The design allows fallback to the "other" ICs without redesign costs -- just some reprogramming of the assembly robots.
The answer to that question is independent from the first two Q&As. :o :shock: :? :lol: :roll:
Signature retired
jdb
Wed Jan 16, 2019 11:17 pm
Similarly unlikely.
The answer is: It's Complicated (tm).
Decoupling capacitors are always over-specified on reference designs - you sprinkle them around to excess, and forget about it. For volumes that the Pi is produced in, every penny counts, so we do a more in-depth design review (typically conducted with multiple board trials and PCB analysis tools). If we can omit a few 100nF capacitors from noncritical decoupling sites on the board, then we save money.
Rockets are loud.
https://astro-pi.org
Burngate
Thu Jan 17, 2019 10:21 am
Thankyou, jdb - I wasn't really expecting an answer, but that makes sense.
So the answers to my questions turn out to be:
Yes, sort of, in that it's done in a far more rational manner
Only partly, in that the "wrongness" was already built in to the datasheets, and the designer was already aware of it
No, because my idle wondering has led me to learn something.
Yukon Cornelius
Thu Jan 24, 2019 9:08 am
I've had a few questions myself about components and layout .
But as another member pointed out , Pi is not " open-source hardware " ,
and although it can be a little annoying for an old timey electronics tech like myself ,
I think that it's a smart decision .
If nothing else , it makes it a bit harder for the would-be counterfeiters .
A vast amount of resources went into creating and developing the Pi
and AFAIK it's a non-profit organization so it's vital to protect the intellectual property .
It would be a bad scenario if folk ended up buying fakes unwittingly !
There are some block diagrams on the wiki page , and some good board photos for the various models
but that's all I could find that might help .
Here's an example
https://en.wikipedia.org/wiki/Raspberry ... Bottom.jpg
:lol:
I would have called that the " track side " rather than " Bare Bottom " ,
but now that we have smd components , and layered boards with plated-through holes....
.... I guess the term has lost meaning
mahjongg
Thu Jan 24, 2019 3:34 pm
Cost optimizing a design by removing unnecessary components (after a thorough Assessment process) is standard in any industry where products are made in such large numbers that the cost of assessment is worth the cost reduction.
as for board side naming, standard is component (top) side versus solder (bottom) side, which side is the "component side" is determined on which side the primary components, like connectors, are placed. But yes, its just a rule of thumb naming convention, it stems from the time all components were through hole, and boards were (only) wave soldered.
Thu Jan 24, 2019 4:20 pm
Simples. If your board works, simply don't worry about it.
Any PCB in any product almost ever will have areas on the PCB that appear to have parts missing, but in fact are not needed. It's just that because they are in cases, you never see them. Because we sell a bare PCB, any component that appears to be missing is much more obvious, but there is still not reason to worry, because the devices are tested as they come off the production line to make sure they work, and in fact it is incredibly rare for a pick and place machine + the test systems to miss anything.
Of course it does happen sometimes, but mostly it means the Pi won't work when you get it, and you just need to return to the supplier for a replacement. But that's not necessary unless it doesn't work. And like I said - really REALLY rare.
Will5455
Thu Jan 24, 2019 6:12 pm
Which means that at least most of the people there are doing there job right!
I do strange things and am sometimes the techhead stereotype.
deal with it!
florca
Thu Jan 24, 2019 6:34 pm
Reminds me of the story my Dad used to tell about how Marconi (in their later incarnations) designed TVs - Start off with a really good TV and then take out components one by one until it stops working. Replace the last component. Job done...
drgeoff
Thu Jan 24, 2019 8:14 pm
Not quite that simple. The order in which you take components out is rather important. The CRT was the most expensive component. Start with that one? :)
mahjongg
Sun Jan 27, 2019 7:17 pm
I assume you are confused with "Earl "Madman" Muntz" famed for selling eight-track systems for cars, and for the process of "Muntzing", which means taking a side cutter to an electronic device, (like a black and white TV with tubes) and starting removing components (and soldering them back) to see if the device could do without.
https://en.wikipedia.org/wiki/Muntzing
