Babayaga
ls cannot access /dev/spi* no such file or directory
Mon Jan 14, 2019 7:31 pm
Hi.
I’m newbie with Raspberry; I have a B+ and can’t get the SPI to work.
I’ve checked config.txt and raspi-config, made every update and upgrade but when I type “ls /dev/spi*” the output is “ls cannot access /dev/spi* no such file or directory”.
Any help?
Thank you!!!
danjperron
Re: ls cannot access /dev/spi* no such file or directory
Mon Jan 14, 2019 8:25 pm
Do you have a SPI monitor with touch screen installed on your PI?
Could you provide the config.txt .
Andyroo
Mon Jan 14, 2019 8:44 pm
Have you enabled SPI though config.txt or raspi-config?
By default the SPI bus is disabled on the Pi.
Babayaga
Tue Jan 15, 2019 12:24 am
I’ve enabled it both using raspi-config and config.txt.
In config.txt the SPI line is uncommented and true.
I’ve installed a display but I’ve removed it.
danjperron
Tue Jan 15, 2019 1:31 am
I think that is your problem. Did you removed the driver of the screen?
Please post your config.txt
Babayaga
Tue Jan 15, 2019 7:02 am
Ehm... no, didn't removed them...
here's my config.txt
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
enable_uart=1
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
config_hdmi_boost=7
hdmi_drive=2
hdmi_group=2
hdmi_mode=87
hdmi_cvt 480 320 60 6 0 0 0
dtoverlay=ads7846,cs=1,penirq=25,penirq_pull=2,speed=50000,keep_vref_on=0,swapxy=0,pmax=255,xohms=150,xmin=200,xmax=3900,ymin=200,ymax=3900
danjperron
Tue Jan 15, 2019 12:06 pm
The driver for the display use all the SPI!
Take the display driver out
config_hdmi_boost=7
hdmi_drive=2
hdmi_group=2
hdmi_mode=87
