B4x4
Insert date and time in filname on camera.split_recording
Mon Jan 14, 2019 6:47 pm
Hello all. First question here.
How can I insert tame and date in the filname when i do a split_recording?
I have defined tid as time, and if i insert it as camera.start_recording('1.' + tid + '.h264') it works only for the first file.
As it is under, it does not work.
import picamera
import time
tid = time.strftime("%Y%m%d%H%M%S")
camera = picamera.PiCamera(resolution=(640, 480))
camera.start_recording('1.h264')
camera.wait_recording(5)
for i in range(2, 11):
camera.split_recording('%d.' + tid +'.h264' % i)
camera.stop_recording()
The one over gives error:
File "./recording.py", line 17, in <module>
TypeError: not all arguments converted during string formatting
sys.excepthook is missing
lost sys.stderr
pcmanbob
Re: Insert date and time in filname on camera.split_recording
Mon Jan 14, 2019 8:11 pm
Hi.
You need to update the time/date for each recording, at the moment you have it only updating once at the start of the program.
You need to make it the first line after the for statement.
And please when posting code use code tags as python relies on indentation to work correctly.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Return to “Python”
