hamongnguyetthanh
pigpio error: "no permission to update GPIO"
Mon Jan 14, 2019 4:13 pm
I work on script so I want control to backlight of LCD screen with PWM(software). It is worked earlier but it does not work now. I commented out bakclight divide and worked on the other modules on software. Now I want use but I took this error. I researched on net but I could not fix this. How can I fix this error? My pwm code divide this:
improt RPi.GPIO as gpio
import pigpio
pi=pigpio.pi()
print (pi.connected)    #Test for pigs t
gpio.setmode(gpio.BCM)
gpio.setwarnings(False)
gpio.setup(33, gpio.IN)  #Pin of DW button
gpio.setup(30, gpio.OUT) #Pin of backlight
gpio.setup(39, gpio.OUT) #Pin of lcd on/off function
DirkS
Re: pigpio error: "no permission to update GPIO"
Mon Jan 14, 2019 7:05 pm
Post the *full* error message *and* the code that causes the error (the code you posted above will crash on the first line, because there's a typo)
Use code tags for both; see viewtopic.php?f=32&t=84477
mahjongg
Mon Jan 14, 2019 11:16 pm
added code tags, but left the typo intact.
Andyroo
Mon Jan 14, 2019 11:51 pm
Am I cracking (well yes but you know what I mean) but I thought the BCM numbering only goes up to 26
https://pinout.xyz
So, for the numbers used below, should it not be
gpio.setmode(GPIO.BOARD)
Need Pi spray - these things are breeding in my house...
DirkS
Tue Jan 15, 2019 7:10 pm
https://pinout.xyz
There's a GPIO27: https://pinout.xyz/pinout/pin13_gpio27
gpio.BOARD would also fail as that's ground https://pinout.xyz/pinout/ground
Looks like a bit of a mess...
Return to “Python”
